Guys I need Help 06 Dodge, BullyDog Tpup with version 2.2.7 won't start vin mis match
So was upgrading my unit to 2.2.7 from 2.2.6 and thought I would try the CL out for a change.. So I returned my truck to stock, upgraded the unit and installed it on my truck..
I started it and it ran for a couple seconds then died... did this a few times and now it won't start at all...
When I look at the DTC's I see a VIN Mismatch in there and it won't let me uninstall it... ??
I called BullyDog @ 6:24pm and they closed at 6...
I am screwed basically till monday unless I can figure out what to do..
I am going to go outside and try resetting the battery..
Does anyone know if reloading an older version of the firmware on the unit will even install? I have a backup copy of 2.2.6 here.
Any advice or input or home numbers for a BullyDog tech would be greatly appreciated.
The only DTC I get is P0513 which is a theft deterrant code wrong key, I assume this has something to do with the VIN Mismatch.
Oh and I was inspired to ask this here because of this thread that I googled upon.
https://www.dieseltruckresource.com/...d.php?t=104634
1 Post
Unfortunately, your pretty much hosed until you get a hold of BullyDog. Supposedly when this happens, they will e-mail you or direct you to a special web page where you can download a special recovery program, flash your downloader with it, and your back in business. You gotta get a hold of them though. If you have any local BullyDog dealers, they may have a copy of the recovery program and can hook you up. Try the dealer locator on BullyDog's web page for the one nearest to you. Being a weekend, they are probably closed as well though. Sorry bud...that sucks.
Man thanks for the reply!!!
I have just been sitting around the house.... washing a truck that I can't move.. lol
I contacted my dealer, who doens't have the recovery program, but put a call into their sales rep in hopes of getting an engineer to call me. . But no luck as of yet.. so I guess i will just be late to work on Monday untill I can get ahold of their support line and get my truck fixed.
I need to leave my truck alone that is what I have a race car for yeah know.. but these diesels interest me alot! It is funny to blow away stock camaros at the track in a big truck..
Thanks for your reply.. you are the first among 2 boards..
i had the same thing happen last week they sent me the file to fix the vin but it still did not start so then they sent me the triple pup and i used that to get it started they told me to send both programers back and they are going to send me a new one
all fixed now
So basically I called them this am when they opened, a guy named Liberty helped me go through and input the correct VIN for the truck, then installed the tune again...
And all is well.. Couldn't have been simpler, however I do regret not having an afterhours support line to call for something so simple..
Thanks to all that provided me info and help!!! I appreciate it!
jerrywoodie
26
06-30-2012 09:37 AM
Blacksdieselhp
07-24-2009 03:30 PM
Blacksdieselhp
10-27-2007 04:33 PM
Booger
18
05-23-2006 06:18 PM
samgovol
02-26-2006 10:08 AM
