BullyDog version 2.2.7.
Old May 21, 2006 | 01:38 PM
Booger's Avatar
Finally upgraded from the 222 to the 227 version today for the foglamp with high beam option and the accessory delay option. What a waste of time that was. Neither of those options even show up in the main page screen when I hook it up to my truck. Could it be for the 2006 only? Anyone else have this problem? I haven't driven the truck since the upgrade to see if there is any difference in performance but if there isn't then I guess the upgrade is useless for 2005.
Old May 21, 2006 | 05:59 PM
Black Dog's Avatar
I have the same issue with mine. I'm running the 2.2.7 and no fog lamp option or seatbelt minder option. I called Bullydog Friday about this but they never called me back. I will be in touch with them Monday. Have you tried your CL setting yet?
Old May 21, 2006 | 08:48 PM
Booger's Avatar
I did not do the CL setting. It seems to be hard on the clutch. I use the performance setting and rarely even use extreme. Did you get CL? If so is it alot more than the extreme setting?
Old May 21, 2006 | 09:03 PM
Black Dog's Avatar
I haven't done any upgrading yet, my downloader came with 2.2.7. I don't want to loose my extreme setting only to find out the crazy larry setting is to hard on my tranny and then my only option is to back down to the performance setting. From what I understand the CL program write over your extreme setting. I do run my truck on the extreme setting all the time and it runs great. Im still looking for a little more bottom end, if I new the CL gave more bottom end and not just top end I would download it right now.
Old May 21, 2006 | 09:10 PM
CButler610's Avatar
To clear this up: the CL setting will become the extreme setting. You will literally go from Performance to CL. This is a big jump. I would like to see two Extreme settings: regular and CL. This would be nice, right?
I am not sure if I would be more concerned with your trans. or the stock turbo. If you drive real, real nice on CL you may be ok for a little while, but this is not the way to enjoy.
BTW, I just went from 2.2.5a to 2.2.7 yesterday. I have no time on this tune yet. I will find out tomorrow.
Chris
Old May 21, 2006 | 11:12 PM
06bluetank's Avatar
So if I download CL on mine do i lose Performance and extreme or just lose Extreme?
Old May 22, 2006 | 06:57 AM
Black Dog's Avatar
You just loose the extreme. The problem is, I don't think you can get it back. Once you've upgraded to the CL and you find out it's too much for your truck, now you're only option is to go back to the performance setting.
Old May 22, 2006 | 07:05 AM
Atlantic4x4's Avatar
You can get back the extreme setting, all you have to do is go onto Bully Dogs website and write over the CL setting and then you will be back to the normal 2.2.7 version. Make sure you return the truck to stock befor downloading any program.
Old May 22, 2006 | 03:42 PM
BrentK's Avatar
Booger, I have the 2.2.7 in my 06 and have all the options working fine. Seat thing and the fog light thing. I'd be checken with Bullydog or try the download again.
Old May 22, 2006 | 07:25 PM
Booger's Avatar
From what I am seeing they work on the 06 and not the 05.
Old May 22, 2006 | 08:31 PM
Black Dog's Avatar
I've had a call in since Friday about the lack of options for the 05', and like everybody said the customer service sucks!! They said Monday would be the latestthey would get back with me, but I never heard from them. It's a good thing I like their product.
Old May 23, 2006 | 12:16 AM
lightening ram's Avatar
i upgraded my downloader to the cl 2.2.7 and it works awesome, i [no sh$t] pulled my 12k fifth wheel on this setting this weekend it worked ok just as long as your easy on the pedal, i pulled out to pass on a uphill and hit the throtle hard and the torque chattered a bit but otherwise everyday driving you will see your fuel mileage increase considerably.
Old May 23, 2006 | 10:31 AM
Black Dog's Avatar
Just spoke with the guys at Bulldog. They said 2.2.7 should have those options for the 05' and the 06'. They also said if you didn't have the CL downloaded, than maybe you could download 2.2.7 with CL and the options would take on that download (maybe). They said if that didn't fix it just be patient and there would be a 2.2.8 in a week or two. This is the first they have ever heard of this, so they say.
Old May 23, 2006 | 10:40 AM
Black Dog's Avatar
FYI
Bullydog says the CL for the 05 and 06 is a 180hp and 310tq. The 230hp CL must be for the 555 guys or maybe for the Duramax. They said the extreme setting for our trucks is 140hp and 209tq.
SSminnow's Avatar
Maybe since I have an 03, and not 05/06, what the heck are you talking about: seatbelt thing and fog light?????
