Going with the JUICE!!
#31
so if I did first level one then the second setting level 5 that would produce the most smoke with the least amount of power or can you not run a higher setting than the first? If you can I am sure it is not good to be dumping all that fuel into the chamber and not giveing it enough air to burn it off. SO say if a couple of my buddies are standing outside nest to the street and i want to cover them with soot which setting would you recomend? Also remember that I have the six speed so if I lug the motor more smoke? Sorry for all the stupid questions.
#32
You can set the "Low Boost Fueling" to any of the levels (1-5) for any HP setting. My experience so far is that there is not much difference on the low HP settings. It seems to only be until the turbo produces enough boost to match the programmed HP. Maybe I will play some tomorrow on the 80 and 100 hp settings and see if I can really change how much smoke is produced.
For normal driving I would think it is more of a waste and not much benefit to set HP to level 1 or 2 and "Low Boost Fueling" to 5.
#33
#34
I'm not saying i will be doing this all the time just every now and then to see what works the best as for setting it to level 1 and low boost fueling to 5 wouldn't that technically be the most smoke? I am not saying I will run on this setting all the time actually I will probably run setting 1/1 all the time but if I wanted the most smoke to say put some on peoples faces wouldn't level 1/5 be the best just a question. Getting kinda excited to get it put on my truck.
#35
I dont think1/5 would be the most smoke. 5/5 and lug it will be the most smoke probably. Level 1 is not increasing duration much if any, so dont think it will smoke much at that level no matter what.
#36
I can not make any noticeable black smoke on Level 1 or Level 2 even with Low Boost Fueling set to 5. Now on Level 3,4 & 5 that is a different story. Still not a 2gen amount of smoke. Need a fuel pressure box stacked to get that kind of over fueling. Of course then you need twins to compensate.
5.0 Mustang Man
10-21-2008 02:50 PM
SconsinSmoker
02-12-2007 09:15 AM
bighornram
13
11-02-2006 08:28 AM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
