Free flow Muffler
Free flow Muffler
Hi
I need some help deciding on a quiet free flow muffler. I have a 2004.5 "600" Dodge 4X4 with 4" exhaust. I will be adding a chip, air box and gauges. I also want to change the exhaust, but leave
the cat in place. I was finally able to convince my significant other to get a diesel because she said "they make very little noice now compared to a couple of years ago"
What muffler can I use that will keep me close to a stock noise level? Is this even possible. I will be getting an Edge chip, AFE proquard seven and the Gauges.
Paul
Paul
pfieber,
A couple of real popular mufflers are the Donaldson M090544 or the Nelson 86131M. I am going with the Nelson because I can get it at my local Cummins dealer. I tried to get the Donaldson from Carquest, but they just started distribution for Donaldson and they haven't got their act together yet. I wish the Nelson had flow characteristics posted like the Donaldson does but I am sure they are similar. I got this info from the respective web sites. Here are some specs.
M090544 MUFFLER
A - Inlet Diameter (Inches) 4
B - Body Diameter (Inches) 9
D - Overall Length (Inches) 51
E - Outlet Diameter (Inches) 4
Rated Flow LR (CFM) 1158
Rated Flow MR (CFM) 1638
Rated Flow HR (CFM) 2006
Back Press LR (In Hg) 1
Back Press MR (In Hg) 2
Back Press HR (In Hg) 3
Attenuation (dBA) 13-18
Product Type Description Muffler, Round, Style 1
Primary Application OFF ROAD APPLICATIONS
Part: 86131M
Manufacturer: NELSON
Part Type: ROUND MUFFLER TYPE 1
Material: Aluminized Steel
Body Shape: Round
Body Size: 228.6 mm (9 in)
Body Length: 1130.3 mm (44.5 in)
Overall Length: 1295.4 mm (51 in)
Inlet #1 Size: 101.73 mm (4.005 in) ID Slotted
Inlet #1 Offset, End View, Horiz: 0 mm (0 in)
Inlet #1 Offset, End View, Vert: 0 mm (0 in)
Inlet #1 Offset, Side View: -76.2 mm (-3 in)
Type: 1
Outlet #1 Size: 101.73 mm (4.005 in) ID Slotted
Outlet #1 Offset, End View, Horiz: 0 mm (0 in)
Outlet #1 Offset, End View, Vert: 0 mm (0 in)
Outlet #1 Offset, Side View: 1219.2 mm (48 in)
M090544 MUFFLER
Part: 86131M
Body Shape: Round
Type: 1
Yep...the votes have it, if you want to keep it quite, but flow1600cfm vs 350cfm on the stock muffler, the Donaldson M090544 or the Nelson 86131M are the way to go. You can get the Nelson at your nearest Cummins or Fleetguard dealer.
The Magnaflow mufflers tend to result in pretty bad drone on some trucks between 2000 and 2200 rpm.
Try a search in "Nelson 86131M 51" muffler" There is a lot of information out there!
MonkeyLips,
I have already decided to use the Nelson muffler, but I see you have posted a flow rate for it. How did you get this information? I couldn't find it on the Fleetguard site.
I searched for Donaldson and read allmost all of the results. I also looked at the Donaldson site and found a 090781 listed. It has the following specs:
4" in and out, centered
length 51", round, unpainted
Atten 15-20dba
Flow 1524 LR
2155 MR
2639 HR
note, similar to 090578, painted
Has here tried it or know anything about it?
Thanks
Skip
Atten 15-20dba
Flow 1524 LR
2155 MR
2639 HR
Thanks
Skip
wurkenman
07-04-2008 05:15 PM
ralphyboy
01-17-2008 08:35 PM
8mpg
05-22-2006 01:35 PM
HighTen
04-05-2004 03:46 PM
