Transfer flow but not transfer flow??
Old May 21, 2006 | 07:08 PM
8mpg's Avatar
Im lookin to put a tank in the bed of the truck but I would like to be able to flip a switch and fill the truck tank without getting out. I drive lots of long distance trips and I hate stopping. Anyone have ideas or ever do it?
Old May 21, 2006 | 07:18 PM
abc4yew's Avatar
Once you get your aftermarket fuel pump in place you can put an electrical operated y valve on the pickup from the new tank and the stock tank. To fill the tank you flip the switch and when the return line from the CP3 fills the stock tank you turn it off. You should put a safety on the switch that turns off the valve when the tank gets full. Or go Trans Flow. ks
Old May 21, 2006 | 07:27 PM
Austin'sDodge's Avatar
Check out northern tool for a direct feed kit. Not sure if its what your looking for.
Old May 21, 2006 | 07:35 PM
8mpg's Avatar
just read about gravity fed kits...sounds good to me, just need to find the right tank. I have a SWB so I dont want something that takes up 24" of the bed...although it might be nice if I dont have to help people move
Old May 21, 2006 | 07:36 PM
8mpg's Avatar
Anyone know where to pick up a plain jane one?? I dont want diamond plate...im going to get it linex'd to match
Old May 22, 2006 | 07:13 AM
Mixer Man's Avatar
I have the RDS 60 gal toolbox/tank with the gravity feed system from Northern Tool and it works great !!! www.zylstraautomotive.com has plain ones if you want but they are $$$$ . I bet you can get a plain one through RDS if you wanted all you have to do is ask .
Old May 22, 2006 | 10:17 AM
T398's Avatar
8mpg,
I don't know what resources ya got around ya, but I picked up mine at a local case equipment dealership. They had the best price in town and had a great selection from plain jane steel to smooth aluminum. I have had a 100 gallon rectangular steel box in other trucks, would be great if your going to lineX it ( 24" H x 45" w x 24" d = 100 gallon).
Hope this helps,
Tyler
Old May 22, 2006 | 12:23 PM
cquestad's Avatar
Um...I know a "cough" business that could fabricate anything mild to wild, aluminum, steel, stainless. It technically would be called a bulk storage tank with a 2" fill and a 1/2" drain. PM me if you would like more info. You may have to wait a bit...the industry is way way way to busy right now.
Old May 22, 2006 | 01:35 PM
8mpg's Avatar
thanks, sent ya a PM
dtmccray
Aug 4, 2013 08:53 AM
capt.Ron
Feb 15, 2008 09:55 AM
ralphyboy
Jan 17, 2008 08:35 PM
Scotty
Sep 11, 2005 12:37 AM
Lightman
29
Mar 8, 2004 12:10 PM
