Factory Stock Turbo Boost Pressure
Old Jan 16, 2006 | 09:58 PM
jd2015's Avatar
What type of turbo boost pressures shoudl I expect to see from a factory stock 06 CTD?
Old Jan 16, 2006 | 11:22 PM
BlueDually's Avatar
tops out at 34-35, levels at 31-32
Old Jan 17, 2006 | 12:13 AM
4x4not's Avatar
I never got abover 31.8psi stock. Not much higher with the Juice, but it doesn't have a "max pressure" record like my X-monitor did so it is hard to tell
Old Jan 17, 2006 | 12:19 AM
hognutz's Avatar
I am pretty sure max boost is displayed in the records with temp, mph and all that stuff. I can hit 38-39 if I turn the defueling up past 36 on the attitude. that is max though.
Old Jan 17, 2006 | 09:11 AM
jd2015's Avatar
Thank you for the information from each of you. I installed a 0-30 psi gauge and was in fear of it being to small of a range for the pressure. I will have to keep my eye on it to make sure I do not run it past the stop point.
Old Jan 17, 2006 | 02:59 PM
fwd talon's Avatar
yeah. cause they look like they are having a ceisure if they are pushed past there stopping point. my buddies evo does it and he has since ruined a 100 gauge.
Old Jan 19, 2006 | 11:46 PM
043500QC's Avatar
I have a question about this. Everyone keeps saying max boost is somewhere in the neighborhood of 34-38 lbs. I`m only seeing 26 MAX with my BDDL on Performance. Does this sound right ? Why am I not building any more pressure than that ???
Old Jan 20, 2006 | 04:50 AM
TexasCTD's Avatar
Part of the reason is that yours is an 04. The 04.5 on up trucks have more boost from the factory. Mine spikes to around 33-34ish, then settles down to around 28-29 at WOT, without a fueling box etc.
But I will agree, that something may not be right on yours if it is not producing more boost with the BDDL.
Did the 03 and 04 trucks have different turbos than the 04.5 up trucks?
Old Jan 20, 2006 | 08:34 PM
043500QC's Avatar
I don`t think there is any differance in the 03-04 and the 04.5 turbo`s, but I could be wrong. After doing a little more reading here and on TDR, I`m satisfied that my boost reading is about right for my truck. I just thought it built more pressure than that.
Old Jan 20, 2006 | 09:17 PM
SolarYellow05's Avatar
There is definitely a difference in the turbos. The 04.5 and newer is controlled by an electronic activated wastegate. Also the exhaust outlet is 4 inches unlike the 03/04s 3.5 inch. I'm not sure as to the other dimensions of the turbos.
Old Jan 20, 2006 | 11:17 PM
madmaxer's Avatar
I have Isspro's and I can see my waste gate open at 29-29.5 psi
Old Jan 21, 2006 | 12:19 AM
stlsparky's Avatar
Mine was also at 30psi stock. I removed the hose going from the wastegate to turbo and plugged it. now it will hit 39psi.
Old Jan 21, 2006 | 05:38 AM
SmokinDodge12V's Avatar
On my 03 stock boost was 22 with just the EZ and boost elbow it went to 32 with the EZ and BDDL I can hit 40.
Old Jan 21, 2006 | 11:16 AM
StrokeThisCTD's Avatar
boost around 32 max stock and when it hits 32 it goes back down to 29 and just sits there the whole time
Old Jan 21, 2006 | 12:31 PM
Underpsi's Avatar
On my dads 05 with the bdpp, outlook monitor and edge ez the outlook says that 44psi is the highest boost number it has seen
97dodgeram2500
Nov 1, 2009 11:51 PM
duster75
Feb 15, 2009 09:44 AM
vwjunkie53
19
Nov 9, 2007 02:27 PM
Bobcat698
18
Oct 22, 2005 12:27 PM
Hummin Cummins
Feb 4, 2003 04:26 PM
