Exhaust tip question
Old May 11, 2008 | 06:27 PM
MTC's Avatar
MTC
Im gonna add an exhaust tip and I just wanna know if you guys had to cut the stock end off slightly or did you just slip it on and tighten?
I know, dumb question, but Im just curious.
And whats better, dual wall or single wall?
Old May 11, 2008 | 07:04 PM
dslpwr81's Avatar
You need to cut it, or the original exhaust will stick out of your tip. The Dual wall is by far the way to go. MBRP dual rolled. TUFF TUFF TUFF! I have backed mine into several rocks and the lip on the tips doesn't bend.
Old May 11, 2008 | 07:17 PM
MTC's Avatar
MTC
Thanks, I kinda figured it would need to be cut. MBRP...thats the one Im going with.
Old May 11, 2008 | 07:29 PM
Fiftygrit's Avatar
Ive got the 5 inch slash cut rolled tip and no you dont need to cut nothing, with the tip on you cant even see the exhaust tip inside. works and looks fine.
Old May 11, 2008 | 07:45 PM
dslpwr81's Avatar
With my 5" angled dual rolled tip, when I slid it over my exhaust, you could see the original exhaust tip if you stepped back a little ways. Fiftygrit, you must not have the MBRP because it is a dual wall all the way through. Other dual walls are only dual toward the end of the tip, so your original exhaust slides in between the two walls. If you don't cut it, your tip will stick out and look funny. You don't want it sticking out passed your tire do you? That is the only way you wouldn't be able to see the original exhaust tip WITH the MBRP.
Txwelder
Feb 22, 2008 04:55 PM
Eddy Reyes
Sep 9, 2007 05:20 PM
wcbcruzer
Jul 11, 2006 09:08 PM
Abbynormal
May 15, 2006 07:52 PM
P.J
16
Dec 4, 2005 12:44 PM
