Exhaust manifold?
Old Nov 29, 2006 | 06:39 PM
wap's Avatar
wap
Exhaust manifold?
Maybe I should search some more but I have been on here for a while and dont remember this particular question.
For those that have when to an after market turbo THEN swapped out the stock exhaust manifold for an aftermarket one after drivein with the stock manifold and aftermarket turbo, could you tell a differance?
I am about a month off from gettin my turbo and if it is worth it I would like to go ahead and swap out the manifold if it is worth it.
The 2 things I am lookin for is is 1 faster spoolup and 2 cooler egts.
Thanks for any info.
Old Nov 29, 2006 | 07:40 PM
Jfaulkner's Avatar
Muted User
I did the manifold first (ATS) then turbo but I didn't notice any real difference. The ATS is definately a better piece but I'm not convinced the benifits were worth the price. The EGT's were probably a little lower but I'm not sure if they are $400.00 lower. I am going to switch to a 2nd gen manifold as soon as I get motivated, I hope to get rid of that annoying exhaust note these 3rd gens make and so far have narrowed it down to the manifold. (sounds like a large honda).
Old Nov 29, 2006 | 08:03 PM
lowboy18011's Avatar
I like my ATS manifold. Flows better than stocker for sure. A little porting would make it even better.
Old Nov 29, 2006 | 08:08 PM
wap's Avatar
wap
I thought it was the 3rd injection event that made em sound like that
Old Nov 29, 2006 | 08:21 PM
973604x4's Avatar
most turbos require an aftermarket manifold...or so i was told......
Old Nov 30, 2006 | 12:28 PM
Smkn600CTD's Avatar
If the turbo was made for a 3rd gen, then the stock manifold will work most all of the large singles out there.
My PS 62/14 bolted right up
Old Nov 30, 2006 | 03:51 PM
Jfaulkner's Avatar
Muted User
Well that's what I thought also. However Ted Sterner's (P-Pumped) truck sounded like that even after p-pump conversion. Then he switched manifolds because of a turbo swap and it sounded just like a 12v or even a p-pumped 24v.
If you think they sound horrible now you should hear one at 5k rpm with that crappy manifold. I have the video somewhere.
Old Nov 30, 2006 | 04:00 PM
morkable's Avatar
97,, I still have the stock manifold on mine,, maybe next year i will change it,, have to if I want to go to twins
Kevin
Old Nov 30, 2006 | 04:23 PM
Jfaulkner's Avatar
Muted User
I found it
3rd gen manifold
2nd gen manifold w\stacks(no the stacks didn't do it)
Old Nov 30, 2006 | 04:52 PM
wap's Avatar
wap
smkn, I know it will bolt up I was just wonderin about the performance but thanks for the help.
J, what kind of modifications are necessary to put a 2nd gen manifold on a 3rd gen?
Old Nov 30, 2006 | 04:56 PM
dodgezilla04's Avatar
also, when upgrading the turbo and having a turbo mount e-brake, you may have some clearance issues, i did. nothing 5 minutes on the grinder to the e-brake bracket didnt cure.
Old Nov 30, 2006 | 04:58 PM
Luken's Avatar
I still have the stock ex. manifold
Old Nov 30, 2006 | 05:04 PM
Jfaulkner's Avatar
Muted User
Nothing other than you might have to lenghen the oil drain tube, and your intake might (depending on brand) need modified because the turbo is mounted farther forward and farther from the block.
Oh I forgot we also put a 3rd gen (factory) manifold on a 2nd gen and it also sounded nasty. But other than making a new downpipe, everything else fit (oil supply and drain tubes even the intake tubeing fit).
Old Nov 30, 2006 | 05:17 PM
i plan to keep mine stock manifold, until it cracks.
silkywoods
35
Feb 6, 2008 12:40 PM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
Marine
Oct 5, 2003 03:45 AM
texasdave
Nov 8, 2002 08:25 AM
