EGT Gauge Problem
Old Feb 25, 2009 | 05:57 PM
redram's Avatar
EGT Gauge Problem
I have an Autometer Phantom EGT gauge hooked up pre-turbo. In the past few weeks it has been behaving very erratically. Sometimes it's stuck on 100 deg.F, other times the needle will jump around at lightning speed and then it will miraculously start working normal for a while.
I've checked the wiring and there seems to be no short or loose connection. Is there a way to test if it's the gauge itself or the probe acting up?
Thanks for any info.
Old Feb 25, 2009 | 06:17 PM
Mocho's Avatar
I had this with mine, I redid the connection between the probe and line into the truck and it's been fine ever since. It looked ok when I took it apart but for some reason something was wrong.
Old Feb 25, 2009 | 07:26 PM
bishgeo's Avatar
Yea what he said.Mine did it too.Take your cable apart where it connects to the probe clean it with sand paper put it back togeather and keep on truckin.
Old Feb 26, 2009 | 09:59 PM
redram's Avatar
Thanks for the info guys, I'll clean it tomorrow.
jta
Nov 19, 2007 04:35 PM
jmccart
Mar 18, 2007 10:03 PM
0425004x4
May 9, 2006 10:04 PM
0425004x4
Mar 29, 2006 10:36 AM
PThree
Dec 19, 2004 11:02 PM
