drone @ 1500rpm?
Old Jul 30, 2006 | 03:00 PM
35" 05''s Avatar
drone @ 1500rpm?
just installed my true 5" turbo back "free flow" pipe. @ 1500 rpm's there's a good drone. not that big a deal but would a bigger tip help this. thanks for the info
Old Jul 30, 2006 | 08:47 PM
2-Stroke's Avatar
whered you find that at?
Old Jul 31, 2006 | 09:15 PM
35" 05''s Avatar
hey bud, shopdiesel.com. 300$ 5" downpipe and all the way back . sounds like a CAT.
Old Jul 31, 2006 | 09:39 PM
Pooter's Avatar
Had the same drone on my '97 with a 5" system...
Made me put my stacks back on
4" straight pipe on my '05, left the kitty intact, no drone at cruise, ONLY slight drone is convertor locking up...
Old Jul 31, 2006 | 09:40 PM
35" 05''s Avatar
thanks did u have a tip on it or would that not make a difference
Old Jul 31, 2006 | 09:48 PM
Pooter's Avatar
On the 5" system, it went all the way out, past the rear tire, pipe that was in the kit....
It was a 4" downpipe, and 5" all the way back...
Lost some spool time too, felt a little more lag...
That was just my experience with the 5" systems...
Keeping the 4" on my '05 for a while, it flows well enough and sounds decent...
Might help to try a dynomax bullet, or like, straight thru muffler to eliminate some of the drone...
Otherwise, stock up on sound deadner
<- had lead plate from Xray rooms as sound deadner, and no I didnt do it, was on the truck when I bought it, but it actually works pretty well
Old Jul 31, 2006 | 09:53 PM
35" 05''s Avatar
yeah i cant tell if theres a lag or not. it seems like since i put it on the clutch slips more. i think that its because it ads power. mines 5" downpipe also
Old Jul 31, 2006 | 10:04 PM
Pooter's Avatar
Stock turbo?
Old Jul 31, 2006 | 10:40 PM
4x4not's Avatar
I get a slight drone right at 1500rpm with my stock 4" exhaust with muffler removed via MEK from Geno's. It is more noticable while towing. Not too bad unloaded.
Old Aug 1, 2006 | 11:29 AM
david_4x4's Avatar
I have some good droan in my truck 55mph@1500rpms when the truck is going into overdrive. All I have is a 4" straight pipe with everything removed.
Doesn't really bother me unless I'm at 55mph on traffic.
copperlittle
Apr 20, 2008 09:42 PM
dsljunkie
14
Aug 9, 2003 09:18 AM
70DUSTER
Jun 26, 2003 11:31 AM
45
Jun 4, 2003 01:42 PM
cummins24
Jan 29, 2003 05:47 AM
