Drive Preassure and boost gauge ?'s
Old Apr 20, 2008 | 02:41 PM
tristan21's Avatar
I was into "Wildcats Ho!"
Old Apr 20, 2008 | 02:45 PM
tristan21's Avatar
Or this
http://www.youtube.com/watch?v=JEsHU...&search=he-man
Old Apr 20, 2008 | 06:23 PM
awenthol's Avatar
Like XLR said, drive pressure can tell you where to set certain parameters like your wastegate, for max efficiency...
Old Apr 21, 2008 | 07:59 AM
tristan21's Avatar
right more of a gauge for setup than a safety issue. All the same I think I will look into it. Since I'm gonna need some analog gauges anyway with the fuel issue on the commander.
Old Apr 21, 2008 | 09:55 AM
enafzige's Avatar
I used my drive pressure gauge to "tune" my exhaust brake to the maximum recommended 62 psi backpressure.
Plus, it's just something else cool to look at, helps you practice mental math skills on the fly as you're trying to calculate drive pressure to boost ratios, lets you "see" exhaust braking performance, etc.
Maybe there is something to the filter thing though...mine worked great for about 2 months
--Eric
Old Apr 21, 2008 | 10:36 AM
53 willys's Avatar
I wonder what would work best for a soot filter?? some steel wool maybe???
Old Apr 21, 2008 | 12:32 PM
XLR8R's Avatar
Our TIP Kits have soot filters that are designed to be backflushed as needed.... should be cleaned at least once per year.
Old Apr 21, 2008 | 01:14 PM
enafzige's Avatar
Hey Mike!
Would you care to recommend the type of filter used for those of us who already have the gauge in place? It looks like from the pic on your website that it's a Swagelok/Parker/etc inline gas filter...If so, what micron filter works?
It's obvious a filter is needed, as my gauge stopped working, but I'm not sure I follow the logic behind needing one. There is presumabley no "flow" through the line connected to the gauge, but rather the gas in the line just compresses and expands to relate indicated pressure on the gauge. In fact, it would seem, that, since the line contains clean, ambient air when installed, that the slug of gas acting on the gauge would be free from particulate matter even without a filter...
I'm in no way second guessing you, but I'm just trying to make things make sense in my head!
Thanks Mike! Eric
Old Apr 22, 2008 | 01:10 AM
XLR8R's Avatar
I'm not sure which gas filter you're looking at, but it sounds like it would work. Ours are machined into the compression fitting & it's been a long time since I spec'd the micron rating for it.
Did your homemade drive pressure gauge read smoothly while it was still working?
BTW - although the capillary doesn't exhibit any flow in a throughput sense, there are convective currents present such as found within a heat pipe.
Old Apr 22, 2008 | 10:56 AM
enafzige's Avatar
Yes, when it was working, it worked well. It was smooth, and had very quick response.
I tapped into the exhaust manifold, used a stainless swagelok male connector fitting, and ran 1/8" 316 SS line to the cab/firewall. From there, I used parker nylon tubing up to the 0 - 100 psi DiPricol Optix boost gauge.
I guess I need to order a new gauge, and install an inline filter...
--Eric
Old Apr 22, 2008 | 11:57 AM
tristan21's Avatar
Maybe im missin it XLR8r are your tip kits only outside mount like the 60's and 70's hot rods or is one of those gauges in the picture thats inside the cab?
Old Apr 22, 2008 | 12:41 PM
53 willys's Avatar
I made a homemade inline filter last night at work...I used some 000 steel wool...and some aluminum tubing..I will let you guys know how it holds up....after I get it installed
maybe368
Feb 14, 2014 04:56 AM
Tank_66
Feb 28, 2008 08:34 PM
Mark03Ram
Jul 13, 2007 07:42 AM
tristan21
Jan 17, 2007 05:51 PM
cLAYH
Jan 15, 2007 11:06 PM
