The Definitive Howto: 04.5-05 Tc Lockup Switch
i dont mean to beat this horse to death but i just got confused (surprised)
anyway i have an 03 which one of these do i need to do on an 03 ....the 33ohm resistor, or do i need to jump the wires in the fuse box or do i just need to hook up the switch and ground and do nothing else thanks
You need the jumper wire, not the resistor on the 03/04's. Works perfect!
1. At what dealership did you get the reflashed done and what was
their opinion on this program?
2. I went to the dealership in Stony Plain, Alberta with the TSP
(21 - 006 - 06, March 20, 2007). The person their said, The program
that was in my truck, new 2005, was best ????????????????????
(can not locked out OD, push tow/haul button, after a one tenth of km it
shifts back into OD).
3. I would like to talk to you on telephone about this?
(What is best way to get in contact which each other!)
Any of the electronic gurus here know if a 1k resistor would work instead of the 33 ohm? I have an unused one that came with my radio, with a long wire and wire tap already on the end. If it doesn't work would it just set a code that can be cleared with the Smarty?
I don't think it will work. I read somewhere in the pages it had to be within a range and The K's don't work.
OK-- now I'm confused. Did the mod as described here. Triple checked everything with the instructions here. Did the jumper; ensured the poles were the right ones. Tranny is stuck in third gear.
What the heck happened?
It takes off in third gear (acts just like the brake is on) will not shift regardless of lever position (1,2 or D) tow/haul makes no difference. It will do what it is supposed to in R, N or Park. But it acts almost like a CVT now. Starts really slow (in 3rd) and just keeps building with no shifting and the torque converter will NOT lock up. It does not matter what position the switch is in. Finally I disconnected the wire to the tranny and all went back to normal.
Does ANYONE have an idea what the heck happened??
Yeah, you're right it shouldn't make a difference. Was just thinking maybe it could freak the ECM out and put it in some kind of limp mode.
Guest
Posts: n/a
cool, I thought maybe I was hurting something without knowing it. I use mine as a "kill" switch at night. My hope is that if someone trys to steal it and does get it started that as soon as they take off and it dies they'll just leave it.
