Boost XZT VA3.2
Boost XZT VA3.2
I put the Van Aaken C3.2 on the truck about a week ago and have a question. Shouldn't the XZT allow boost to get over 32psi? Now with the switch on the va, truck goes faster, boost climbs to 32 quick then stays there and hisses. Even in the "off" position, the new box makes a little smoke at shifts and builds boost faster.
How are you measuring boost? or should I say what are you using?
I do need a lift pump and will get one shortly, but I don't think it's the problem now. I've only run the VA on high a couple times and I felt what happens when it runs out of fuel. This is different, and it happens with the box in all three positions always hisses at 32psi, but seems like there's still plenty of fuel, just air pressure stops rising at that point.
The light on the xzt box goes green, orange, orange, green, then goes to red and stays on. Is this the correct sequence? What else can I check to see if boost fooling is working. Also what is stock wastegate set at?
sCreamin400
11-02-2008 01:46 PM
powerstrokin03
09-25-2006 07:07 PM
flyfsh70
09-13-2006 07:32 AM
trik396
04-29-2006 02:25 PM
Dodgezilla
16
11-05-2005 11:49 AM
