Boost Question
Old Jan 26, 2009 | 05:32 PM
03RAM2500's Avatar
Boost Question
I removed my quadzilla commander and replaced it with a set of autometer phantom gauges last week. The commander never showed more than about 31-32psi of boost. Now, with the mechanical gauge, I can hit 40psi pretty easy with my smarty on revo 7. Is this normal and is it safe? I have the boost line ran into my cfm intake horn. Also, is it normal for the gauge needle to shake and vibrate after it gets above 30psi? Thanks
Old Jan 26, 2009 | 09:29 PM
03RAM2500's Avatar
Anybody seen this?
Old Jan 26, 2009 | 09:41 PM
055055.9's Avatar
I have the same gauge also vibrates after about 30 psi.
Old Jan 26, 2009 | 11:47 PM
TrkEnvy's Avatar
The needle vibration is normal.. The only time you wont get the needle wabble is if you use a liquid filled gauge..
Old Jan 27, 2009 | 05:40 AM
03RAM2500's Avatar
Thanks, is hitting the 40psi normal and safe with my mostly stock truck?
Old Jan 27, 2009 | 07:03 AM
madhat's Avatar
Administrator/Jarhead
Yeah, I was hitting 40 with my edge and no studs... the stock turbo is not very effective around 38ish and up. My edge would only read 32-35 psi, while my gauge was showing 40+.
Might want to save up for some studs. While you have it all apart, take the plunge and get springs and sticks... (I love spending other people's money! )
I think that I have read that our stock head gaskets are good to around 50 with out studs, but that's pushing it. The HG's in our trucks are very good.
hth...
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
