boost question
Ok, now I take offense to that bolded statement.
There are digital gauges that still use regular electronic boost/pressure/temp sensors. I would put my SPA gauges up against any mechanical/analog gauge when it comes to accuracy and response times.
I think what Soulezoo was getting at is that you don't want a gauge/monitor that simply uses the stock boost sensor. That sensor is being "fooled" by the module/programmer and won't read accurately. As you've already found out too, they don't have a high enough range to read accurately with a bigger single or twin turbos.
The sensor's not being fooled, the ECM is. As long as you're not making more boost than the stock sensor can read (around 41 p.s.i. I think) reading from the stock sensor is fine. But reading from the OBDII port is a no-no. And Quadzilla now has an adapter of sorts that allows you to use mechanical methods of reading boost with the Commander. Best of both worlds to me.....
The sensor's not being fooled, the ECM is. As long as you're not making more boost than the stock sensor can read (around 41 p.s.i. I think) reading from the stock sensor is fine. No reading from the OBDII port is a no-no. And Quadzilla now has an adapter of sorts that allows you to use mechanical methods of reading boost with the Commander. Best of both worlds to me.....
Oh, I'm sure I can do it-- have not split a turbo before though. Not easy to remove the turbo-- gotta basically take everything out before removing the turbo and the four nuts bolting to the manifold are just stupid. The downpipe is actually the easy part! I'll give PDR a buzz and see how much--
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
