Boost Fooler/smoke Switch?
Does Anybody Know How The Boost Fooler With Edge Ez Should Be Hooked Up For The Smoke Switch?, Do You Hook Up The Switch To The Boost Fooler Or The Edge Ez?, And Which One Goes To The Map Sensor First The Edge Ez Or Boost Fooler? help Please!!!
Why do you need the boost fooler with the EZ? It's got built in fooling capabilities according to the boost readings I got with it versus stock when I had mine installed. If both are fooling, you could possible get an overboost code.
I Dont Know Why But It Keeps Throwing A Boost Code Everytime I Turn The Switch On With Just The Ez. Thats Why I Wanted To Know How U Hook Them Up Together, Because I Didnt Think That The Ez Does Boost Fooling? Does Anybody Know For Sure?
I'm positive the EZ has boost fooling built in. Are you leaving the switch on for a long time? I know if you leave it on for a while it will eventually throw a code.
As for the hookup, I think you are supposed to hook up the fooler and then the pressure box. The smoke switch needs to be tapped to the wires on the EZ in order to work correctly. At least that's how it is on Quadzilla's boxes. I would think it is the same for the EZ too.
From what ive always seen from my ez it does little or no B.Fooling. On my truck with just the ez- the addition of the quad b.f. makes a lot of differance. 10-12 lbs boost and pulls lots harder.
But no matter what if it didnt somehow or somewhat alter the map signal it wouldnt hook up to the map sensor. For what its worth the day i ordered my B.F. over a year ago i called edge and asked them that question so as to know wether the quad unit would help me or not. The tech i spoke with said no the ez is our only product that doesnt though?
Killdmycobra
Nov 12, 2010 05:15 PM
Mind If I Smoke
Sep 13, 2007 11:51 AM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rockittboy
Dec 27, 2006 09:21 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
