Boost Fooler Question
Old Jan 1, 2008 | 07:41 PM
Big Smoky's Avatar
I just installed my Quadzilla boost fooler I got used today. My first question is, do I install it with the plug on the boost fooler connected directly to the MAP sensor and then to the Power Puck, or have my puck conected to the MAP sensor and then install the boost fooler after the Puck? Right now it's hooked with the boost fooler connected to the MAP sensor and then to the Puck. Also, I just went for a drive and at low speeds it seemed to studder and jerk. I flipped the Puck off and then it quit and I couldn't get it to do it again even with the Puck on. It has never done this before. Any suggestions? Thanks
Eric
Old Jan 1, 2008 | 08:34 PM
bluechrome's Avatar
Plug the BF into the sensor first then the power puck. I think that is correct. You'll know if it is correct if the little green led lights up.
Old Jan 1, 2008 | 08:43 PM
stock600's Avatar
The light will come on anyway. I called quad to ask the same question about my quad B.F and edge ez. They said always plug the pressure box in first to the map, then the B.F. then the factory harness.
Old Jan 1, 2008 | 08:50 PM
Big Smoky's Avatar
Ok, so plug in pressure box first and then BF? Will do. Thanks
Old Jan 1, 2008 | 08:52 PM
bluechrome's Avatar
I wouldn't put it past myself to be wrong it was a late night last night
Old Jan 1, 2008 | 08:54 PM
stock600's Avatar
No problem good luck. I to quessed at first and got it wrong. Dont remember the details of how it ran but it wasnt correct. Later
Old Jan 2, 2008 | 06:28 PM
Big Smoky's Avatar
Well, I switched it around to where the puck is hooked to the Map and then the boost fooler hooked to the puck. Sometimes I've noticed the truck will stutter if I give it throttle. I let off the throttle or switch the Puck to a different level, it will stop and doesn't do it again until the next random time. I really haven't noticed that big of a differnce with the BF though. Any thoughts? Thanks
Old Jan 2, 2008 | 06:34 PM
rustyshakelford's Avatar
the bf isnt going to give you big gains. i think i maybe got another 8 psi out of mine. didnt really notice alot of power gains or large reductions with my egts becuase my turbo was way out of its effective range
brett
Old Jan 2, 2008 | 06:35 PM
Big Smoky's Avatar
I didn't think I would get much gain but the thing is I haven't seen that much boost gain or reduction of EGT's and I only have a Puck.
Old Jan 2, 2008 | 06:40 PM
do you have an electronic wastegate?
brett
Old Jan 2, 2008 | 06:48 PM
Big Smoky's Avatar
I don't think I do because it's an early '04. If I don't have an electronic wastegate that would mean you would have to physically do something like a boost elbow. That makes sense.
Old Jan 2, 2008 | 06:54 PM
06CTDforAU's Avatar
Correct. So what you need is a boost elbow to effectively use the boost fooler. I didn't think the early '04 models had an electronic wastegate.
Old Jan 2, 2008 | 07:03 PM
cool. im glad you saw where i was going with that
check out ebay for some good deals on one
brett
Old Jan 2, 2008 | 08:06 PM
Big Smoky's Avatar
But would running a BF without an elbow cause or have something to do with the studder I sometimes have?
Old Jan 3, 2008 | 05:04 PM
stock600's Avatar
I had that happen before when switching things around a lot, i got a small tube of dielectric grease, put some in the ends and reconnected everything, made all the differance. And ya on your 04 i could see not getting much use from it untell you block or adj. your mech. wastegate. Once you get more press. the B.F. will allow you to continue fueling that additional air plus keep any codes away. BTW i noticed a lot more adv. using mine with my tuner rather than just my ez, and even better with them both!
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
GTSDave
Jul 8, 2005 09:06 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
