boost fooler
boost fooler
Any body running a boost fooler on an stock 06 cummins? And is it worth the money? And what is the difference between the quad and bd????? Oh sold the 97 so no more drag truck to build.
Looking for another thought.
Before the Jr. I bought a BD boost fooler with the hopes of less egts being the main bennefit. It did not work at all, and when talking to several people at BD I was told that it was not meant for that application and would not work. I then took it back and got a quadzilla and it worked wonders. Same product, but the QZ worked. It took a good 200 degrees off my exhaust temps, and just made the truck more responsive. A good and cheap investment in my book.
I just got the QZ fooler. I can say it works... But, they make them for trucks with programers. If you like using your PMT for you gauges... I would not recommend. The PMT only shows 23#'s now, even though the boost is much higher. I was seeing 28#'s.
So my question is to these companies that make products for a specific applications (programers), why don't they design them so you can still use the most important features (gauges)?
i run a qz boost fooler with my jr... with the jr i wasnt able to get above 30lbs, with the install of the boost fooler im knocking on 40lbs every so often..
I would probably see #'s like that but with the programmer... I guess its just not possible to see the real boost #'s. So, even with a screne I spent a pretty panny on, I still need to install a boost gauge?
Maybe there will be a boost fooler setting on the new PMT download. Thats what I'm hoping for.
My understanding is most modules will boost fool, but because programmers do not mess with the MAP sensor they do not boost. I can see Smarty figuring a way to get by that though.
Scottabrad where does your wire connect to read boost?
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
GTSDave
Jul 8, 2005 09:06 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
