Boost fooler
Old Dec 30, 2006 | 10:37 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Originally Posted by MikeyB
Doesn't the quad boost fooler come with one in the kit?
MikeyB
Can anyone confirm this?
Old Dec 30, 2006 | 11:52 AM
VaultRam's Avatar
You would need to get a boost elbow.
MikeyB
From the DTR shop and the Quadzilla website:
"On 2003-2004 5.9L Cummins you will need to physically modify your wastegate to gain more turbo boost. Doing this without the Boost Fooler will result in check engine lights and codes set into the computer. Stock 03-04 trucks should generate 23-24psi of boost pressure stock. With the Boost Fooler you will be able to run 35+ psi of boost dependent on your fueling enhancements."
I'm sure that it doesnt come with the boost elbow but I might be wrong!!
Old Dec 31, 2006 | 10:13 AM
sqrl$$'s Avatar
what boost is safe? I can nail mine getting on the highway and my attitude will chirp at me at 40psi. Just running stock exhaust with intake kit and juice w/attitude.
Old Jan 2, 2007 | 10:49 AM
qzilla's Avatar
The boost fooler does not come with a boost elbow. The boost fooler is simply electronics.
Also the bosot fooler does not do anything at lower boost levels, it only fools boost when needed to keep the wastegate closed. It should make no difference in performance until you are near your trucks factory boost limit.
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
GTSDave
Jul 8, 2005 09:06 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
