banks and boost fooler ?
Old Mar 28, 2007 | 12:17 PM
rip 112's Avatar
Question banks and boost fooler ?
Should (could) I use a boost fooler with the six gun? Im not sure if banks has boost fooling capabilities on board, nor do I know if it would be safe for it, but I want more boost without upgrading turbos for now. Suggestions?
Old Mar 28, 2007 | 01:37 PM
rip 112's Avatar
Anyone? I want to put it on today, but I just want to be sure I'm not screwing up.
Old Mar 28, 2007 | 02:45 PM
qzilla's Avatar
Well, I can tell you it is not going to hurt anything. I just do not know how much benefit you will be seeing.
I see you have a new wastegate actuator. You may have to adjust on this or completely block off the vacuum side to see more boost?
I am assuming you have a boost gauge already? This way you can sort of monitor the change if any.
Lastly, I would install the Banks MAP sensor first and then the fooler so that the ECM is actually getting fooled and not the 6 gun.
Let us know how it works for you. I always preached it to be for downloaders but, we have had a lot of people running them on the Juice and they say it helps a lot?? Maybe we will be able to add Banks to that list?
Quad
Old Mar 28, 2007 | 03:26 PM
rip 112's Avatar
[quote=qzilla;1431663]Lastly, I would install the Banks MAP sensor first and then the fooler so that the ECM is actually getting fooled and not the 6 gun.[quote]
I'll give that a try. I just wanted to be sure that it wouldnt hurt anything. I'll post the results later
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
CDoskocil9
Sep 21, 2006 09:26 PM
GTSDave
Jul 8, 2005 09:06 AM
