Quadzilla Boost Fooler with Banks Six Gun PDA
I have a 2006 Dodge Ram With Banks Power PDA and six gun with this setup I've seen 36psi boost.... Everything else on truck is stock besides the new style K&N For Diesel Only Vehicles....... If I stacked the Quadzilla boost fooler what benfits will I see?
Thanks
Thanks
Probably none, I dont think the turbo is doin much after 35lbs.
I guess you may get higher boost numbers but that is just gonna make higher dirve pressures and move heat, not good cool air.
I have seen mine spike up to 50 +or- about 2 and it makes me cringe just thinkin about it.
Buy a Quad module or anything else and get away from Banks.
Banks is supposed to do boost fooling so stacking the Quad with it i don't believe would go over well...probably screw with that bling bling of a PDA.
The boost fooler would then be intercepting signal between your banks module and the MAP sensor. that can't be good.
and let me testify since i own a Quad Boost Fooler.....I LOVE MINE! On crazy larry pre-boost fooler i could only see around 33psi and the crazy larry was pretty dead on the top end with excessive EGTs. WITH my boost fooler, it pulls LOTS harder all the way to 110mph with LOWER EGT's...plus smoke is more manageable.
keffa11
Jul 9, 2008 10:56 PM
lowboy18011
Jan 31, 2007 11:17 PM
Lrdchaos
Feb 7, 2006 09:57 AM
Canadian JR
Nov 12, 2005 04:43 PM
