Another tranny question????
Old Jul 5, 2007 | 09:22 PM
RunninLean's Avatar
Ok so I am working on a budget here and wa wondering If I would be doing my self any favors by installing a VB? I plan on going with a TC, FP, and input but all of it at once is a good chunk of change.
Will the VB by its self benifit me untill I can get the rest?
Old Jul 5, 2007 | 10:00 PM
badme's Avatar
Valve body is a great upgrade for the transmission. I did my valve body on my 47RE, I will do a converter at a later date.
Old Jul 6, 2007 | 11:06 PM
RunninLean's Avatar
Any one else?
Old Jul 7, 2007 | 12:16 AM
GaveUpOnTV's Avatar
a valve body raises the line pressure, which helps to eliminate slippage, (once it happens, slip, it tends to slip easier next time). Torque converter is about efficiency of power to wheels.
Somebody correct me if I'm off here.
Old Jul 7, 2007 | 05:19 AM
Juiced06's Avatar
Save your money buy all your parts and do it all at once until then take it easy on your truck.
Old Jul 7, 2007 | 08:02 AM
KVD's Avatar
KVD
Juiced06, how you like that TCI converter??
How much did you give for it??
Old Jul 7, 2007 | 10:42 PM
badme's Avatar
How will he save money doing it all at once? If he does the valve body now and saves the transmission all that he is out is fluid when he does the converter. If he waits and smokes the tranny the hard parts he may need will far out weigh the cost of fluid. If you intend on doing any performance mods, do the valve body first. There is no such thing as easy after a performance mod.
Old Jul 7, 2007 | 10:51 PM
Raspy's Avatar
The only TC slippage it might help with is in lockup when the clutch is held with higher pressure. But it will not help with TC efficiency.
I think it is a good move to put in a VB even if you wait on the rest of the improvements. It is a lot cheaper to just do the VB. It is much easier to do and will help with the shifting and internal wear.
John
Old Jul 8, 2007 | 10:37 AM
CoolumConst's Avatar
What do you guys think? 94k miles, tranny does not feel that strong. Should I have it rebuilt with parts from Goerend, suncoast, etc. or buy a tranny from them? What do you think of just doing the VB and TC. If I turn the quad on 100 it will not spin the tires, i assume that the tranny is wasting the power. Just trying to figure out what to do fix up or trade.
Black Dog
Dec 3, 2009 08:18 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
97Dually
May 19, 2005 12:30 AM
Tim9712v
Sep 27, 2004 02:21 PM
boughtadodge
Mar 14, 2003 05:32 PM
