airbox
Old Feb 5, 2005 | 08:33 PM
ftltmp's Avatar
Question airbox
I drilled three 2" holes in the bottom of air box, have not got a chance to drive it yet. Has anyone else done this?
Old Feb 5, 2005 | 08:36 PM
mikmaze's Avatar
I ha d three 3 inchers in the bottom of mine before I jumped on the BHAF bandwaggon..... worked but bhaf is so honkin sexy
Old Feb 5, 2005 | 09:15 PM
04ctd's Avatar
i drilled mine in the bottom (used a dead bolt hole saw) to no effect, then i taped them shut, and did 2 in the front.
no big change on my 4x4 ORP mileage, finally went a FIPK, then a strait pipe. no chg in MPG yet. steady ~16mpg OEM, prolly get ~17 now ...
Old Feb 6, 2005 | 06:28 AM
MikeyB's Avatar
I drilled and installed a plastic 90 degree drain pipe elbow on the bottom of the airbox. The engine seems to breath a little better at WOT. The filter minder doesn't pull down to 100% anymore and I get a little more turbine whine.
MikeyB
Old Feb 11, 2005 | 09:04 PM
nickleinonen's Avatar
i drilled a 4" hole in the bottom of my box before i changed to a bhaf back in last june... i didn't notice any performance gains with the holey airbox but it sounded better..
Old Feb 11, 2005 | 09:08 PM
MonkeyLips's Avatar
Drilled 4" hole in the bottom of the air box (previous truck); used ABS elbow & pipe for home made ram air. Didn't make any difference...that was a stock truck though. It might make a differance if bombing?
Old Feb 12, 2005 | 05:19 AM
JohnnyH's Avatar
I was considering drilling a hole in the bottom of my airbox as well. Once I got to looking at it, I realized the filter would still be very restrictive. I decided to drill 3 3" holes in the top of the box instead. What a diffrence. I almost feel as if I have no restriction at all. And without all that air having to go through the filter element, I've been able to extend the air filter changes indefinetly.
Old Feb 12, 2005 | 05:21 AM
JohnnyH's Avatar
Oh, Is it not April fools day yet. My timing is always off. My box will remain holeless. I may go to a BHAF someday.
Old Feb 12, 2005 | 05:22 AM
Dodgezilla's Avatar
Dude!!!!!! If you drilled holes in the top of the box you are bypassing the filter!!!!!
Old Feb 12, 2005 | 05:23 AM
Dodgezilla's Avatar
You got me!!!
Old Feb 12, 2005 | 07:08 AM
MikeyB's Avatar
MikeyB
Old Feb 12, 2005 | 08:09 AM
mikmaze's Avatar
I'm surprised you didnt juts leave one 90 on the turbo, install a 2 foot long section of pipe that pases through the 6 inch hole you hole sawed in your hood. topped with another 90 facing the wind to act as a nice scoop/ birdcatcher
Old Feb 12, 2005 | 08:17 AM
sawboywv1's Avatar
I cut a hole in the top, installed an elbow, sawed thru the firewall and ran a pipe inside the cabin. That way I can hear it roar and with the A/C on I know the intake air is cold!
Old Feb 12, 2005 | 09:07 PM
triplenickel's Avatar
I just popped out a foglight, and ran a hose right from the turbo to the hole in the bumper. The air is colder down there don't ya know?
Old Feb 12, 2005 | 09:22 PM
Jmac's Avatar
I drilled three holes in my stock air box with no effect on mileage. I scratched that idea and went with the Scotty Ram Air III and gained nearly 1mpg with a legit "seat of the pants" improvement.
My .02
Jamie
MikeyB
13
Apr 8, 2004 08:06 AM
fishin fever
Feb 26, 2004 07:29 PM
Jeff K
Jun 23, 2003 10:14 AM
KatDiesel
Jun 3, 2003 12:15 AM
