stock airbox mods
Old Feb 26, 2004 | 06:11 PM
fishin fever's Avatar
stock airbox mods
Hi all was just at a shop to get a little welding done the shop truck was a bombed 96 daully 4x4 about 400 horse ...now heres the kicker...... k&n filter on modifly stock air box....snookel between box and fender removed fender tunnel blocked off after snookel hole to prevent air from passing by to end of fender has any one done this?? I've hear of mod [more holes ]for scotty's but this seems to work for no extra bucks!!!!!
Old Feb 26, 2004 | 06:56 PM
John_P's Avatar
fishinfever:
I personally tried about every combination you could conceive
on the stock airbox when I still had mine. However,.....NONE
of them even came close to the temperature reduction I have
seen with the Scotty II Air System!! Most of the members
on this site who have tried the Scotty II will agree with that
I think. I also tried the AFE Mega Cannon and did not see
temperatures as low as I do with my Scotty II!!
John_P
Old Feb 26, 2004 | 07:18 PM
infidel's Avatar
I hole sawed a 3'' hole in the dirty side of my 2500's air box w/ K&N (largest you can make without hitting the clean side) and another in the firewall. Then connected them together with 3'' RV dump hose. Left the factory inlet intact. Cost about 50¢ for the hose and took less than an hour. Been running it for close to five years. The turbo whistle will be louder in the cab.
I have a Scotty in my 3500 and results were darn near the same. Both are modified to around 350 HP.
Another advantage of this system is when it gets real cold I can easily remove the hose from the firewall, fold the insulation back over the hole and direct the end of the hose close by the turbo. Believe it or not many times in the Montana winter the intake temps are too cold for maximum diesel efficiency, mileage and power suffer.
There is a several page thread at TDR about this entitled Watch out Scotty.
Maybe someone who is a member could search for it and post a link.
Old Feb 26, 2004 | 07:29 PM
dodgediesel4x4's Avatar
That sounds like a tad bit cheaper than the Scotty system, might try that.
Chris Derrick
Jan 18, 2010 11:35 PM
b.lee
Dec 2, 2006 08:32 PM
v-bar
Dec 16, 2004 03:53 AM
Tengu
May 17, 2004 10:41 AM
KatDiesel
Jun 3, 2003 12:15 AM
