600hp recipe
Old May 6, 2006 | 09:03 AM
  #31
OT-OF-Here's Avatar
by-pass tube
Originally Posted by abc4yew
Plow, and about 1850 ft lb of torque .
Most twins I have seen have either a waste gate, BOV or just a bypass tube so that excess boost can by pass the top tubo and go straight to the bottom turbo. The advantabe of the tial or similar is that the top turbo will spool very quick and the second it achieves it most efficient zone all excess is routed to the bottom turbo to bump it to its most efficient zone. It is definitely the most efficient and prevents a drive pressure excess. The bypass tube works in the same fashion but it will result in slightly slower spooling. If there is tons of fueling and the bypass tube is spec'd right then it is more efficient as when boost is near the wastegate opening threshold the wg starts to open and this creates a turbulent flow in the bypass tube. Having a fixed by pass tube gives a constant and smooth bypass flow. The truck I was in that used the bypass tube spooled way faster than mine and peaked at 65 psi (WG) in a heartbeat. ks
Can you post some pics of that setup??
Old May 10, 2006 | 01:54 PM
  #32
abc4yew's Avatar
I'll try to get a pix of Billy's set up....if he hasn't sold the truck. He got caught two days in a row by the same cop doing 110mph in a 50 mph zone....doing some tuning. 10 points loses the licence and each of those was -8 points. He ran twins with 3 water/meth jets. Regular cab and scary fast. ks
BigBlue
Oct 18, 2005 10:31 PM
countrycoach
14
Oct 7, 2005 10:53 AM
Mechanos
Jan 12, 2004 03:16 PM
