2 mic. filter kit??
How about the one from Glacier since you already have their lift pump kit? 2 micron filtration and the whole kit is under $200 shipped.
http://www.glacierdieselpower.com/pr...id=MK20306-BLK
Several options. GDP makes one , why not go with it? I have made my own, substantially cheaper than GDP's kit, using parts from NAPA. Takes a little time to research what size of filter you want, and to find a filter head that matches it, where to mount it.....ect. Just depends how creative you are, or if you have more money than time. I tend to be lacking in the funds department, so time is cheaper than paying someone else to do the legwork! Nothing against Rich @ GDP. He has actually helped me out with a fuel pump issue I was having. I bought my Walbro pump and regulator thru him, but did the rest myself.
I agree with VZdude. If I had known then what I know now I could've easily built my own equivalent 2 micron kit.
However the Glacier kit is awesome. It has all the parts right there and ready to go. I would not hesitate to use the kit.
Here is mine that works with the engine APPS. I wanted it there for some heat in the winter and it is really easy to get to from under the truck. A simple bracket I made mounts to timing gear case. It is in-line between the stock filter and the CP3.
whitebuffalo
Jul 6, 2008 11:11 AM
vzdude
Feb 13, 2008 09:42 AM
Pinksa
49
Jan 19, 2008 09:18 AM
vzdude
15
Nov 24, 2007 08:36 AM
