Why stack anything with a BD on CL
I understand people are stacking pressure boxes on BD but why? From my reading the BD on performance, Extreme, Crazy Larry adds pressure.. For example the EZ adds pressure. Does it do anything else?
Would that not be too much pressure?
bdtd doesn't add pressure. don't know if they've come out with anything with pressure for the pmt or not.
To make more power with less EGTs in most cases.
If you are happy with the BD TD w/CL power and have EGTs under control then you have no need to stack anything.
As far as BD TD adding pressure I never did get an answer from BD when I was running the BDTD w/CL. Some say yes, some say no, some guess, etc.
Most have found that the proper stack will improve overall performance if not max hp.
Doesn't it add pressure if you select the "Low end Power" option or is it just considered hard fueling.
My buddy has a PMT and it crashed. He had to send it in and they sent him a new one. Last I heard he was still having trouble, something with the program already being installed and the VIN not right even though he sent it in with his number FYI.
