2 mic filter or water seperator
i'm planning to start running more bio to help with fuel expenses. i know cummins allows 20% if additional water seperator is in place, so i had planned to install a water seperator on the frame rail before the factory filter (have the filter head and filter, waiting on the adaptor fittings).
would i be better off just using the filter head and putting a 2 mic filter between the factory filter and cp3? or should i stick with the original plan for f/w seperator. i'd do both, but im running a factory in tank lift pump. does the large 2 mic filter trap any water?
Anything you can do for better filtration , a centrifuge is best , sometimes called spinner , or fuel polishing .
As for regular filters , do not use paper / cellulose , with the chance of water content , the paper expands & plugs up .
I bought a Napa filter that has a clear plastic screw on bottom [ changing just the filter ] that the water drains to , then open a valve to drain water .
But Dieselcraft has a product that is my future best looking / working , system .
http://www.dieselcraft.com/productinfo_1.htm
i run the 7 mic, but have heard of people with water problems and never even a WIF light. bio gathers water moreso than regular #2, so i guess thats why cummins calls for additional water seperation in order to run more than 5%. i have a 20 mic (iirc) filter with water drain on it (says water seperator on filter). my question was more of.....do the large 2 mic filters trap water (2 birds; 1 stone) or should i go ahead and install this f/w seperator.
The OE filter needs to be a 7 mic absolute, the only two that meet this are Baldwin, 5 mic absolute, and the OEM, 7 mic. All others are not up to the new, 2006 TSB, standard...
I would add a 2 mic and a fuel/water sep. I am going to do this on my truck and my dad just did it on his, both with the stock LP. A good filter should not impeded the flow and increase load on the LP or decrease fuel psi. The CP3 is designed as a suction pump so as long as you have flow you are fine.
The 2 mics I know of are not fuel/water seps, so you need both. The PN#'s I plan to run are Cat 1R0750 (2 mic) and Baldwin BF1212 (20 mic fuel/water sep)
racor aqua-blocks and water blocking filters in general can strip out water from fuel. They clog up in doing it though.
If you want to dewater your fuel, the best method Ive found is to put it back in the reactor and heat it while drawing a vacuum. Flashes the water off into steam. Youll want to rig up some sort of condenser in front of the pump though.
You could always install a remote filter closer to the tank. Something like a racor 490R. Those have a settling bowl and the ability to run their own WIF and heat.
Jordan5687
May 29, 2013 07:20 PM
Big Rich
Mar 27, 2006 12:55 PM
