fuel filter/ water seperator drain
Old Sep 13, 2004 | 03:10 PM
jbeauv's Avatar
1) which way does the drain lever open, (hope I have not been driving around with it open) ?
2) There is no fuel draining in either position is that normal ?
Old Sep 13, 2004 | 04:48 PM
infidel's Avatar
Depends on which year your truck is, the drain has been changed at least four times, maybe more.
Old Sep 13, 2004 | 09:11 PM
dieselminded's Avatar
mine just flips down i think ...it goes the same way as the drain line.. the drain tube is ran a ways threw the engine compartment and it takes a while for it to start comming out
if you still dont get any thing open the fuel filter canister and see if it'll flow then . this is on an '02
Old Sep 13, 2004 | 09:27 PM
jbeauv's Avatar
filter drain
Seems to me it should just flow when ever I open the drain valve, but I ve never gotten anything out of it. And being an old plumber I am used to seeing valves handles align with the direction of flow but this doesn't make sense.
Old Sep 13, 2004 | 09:39 PM
get out your rotorooter and run up the drain line maybe its plugged
Old Sep 13, 2004 | 10:01 PM
phox_mulder's Avatar
That will get it flowing for sure.
Gotta ask the question, have you ever changed the fuel filter?
Instructions say to drain the cannister, which is a good idea, then you can wipe out any gunk in there as well as the WIF sensor.
I could never get anything out of mine when I'd check at "every fill up" just like the manual says.
Gave up by the 3rd or 4th attempt.
Tried again when I changed the fuel filter the first time, and with the top opened up, or even cracked to release vaccum, it just pours out of there.
Can't remember which way the lever goes though, as it was 8K ago that I last changed the filter,
and my truck is sitting about a mile south of here.
(at work, truck is at light rail station)
phox
Old Sep 13, 2004 | 10:07 PM
WHITEY's Avatar
my 02 up is open. try parking the truck with the front end on a downhill grade. if its not a clogged tube it will drain then.
Old Sep 13, 2004 | 11:36 PM
d0dg301's Avatar
If you really want to see it drain, unscrew the filter cap and on mine I flip it down and you will drain the entire filter.
Old Sep 14, 2004 | 07:16 PM
Mopar1973man's Avatar
I had the same problem on my 02...
Solution...
Bump the starter and get the LP going. Then open the drain valve. This will clean the drain tube. Then turn off the ignition.
NOTE!: The engine is NOT running when this is done. Only the lift pump will be humming!
Problem Solved!
Old Sep 16, 2004 | 09:13 AM
farmer dave's Avatar
Most of the drain levers have an arrow on them that shows which way is drain. It is kindof hard to see, but it is there.
dave
Metallakid
Oct 14, 2005 03:23 PM
SkyHarborCowboy
Oct 4, 2005 06:18 AM
Patrick Campbell
Jan 20, 2004 09:02 PM
yomitch
Nov 18, 2002 01:33 AM
