Turbo Boost Sensor
Old Apr 4, 2014 | 06:52 AM
Rrloren1's Avatar
Turbo Boost Sensor
I have been getting a code for this sensor for several months, can it be removed and cleaned or does it need replacement?
Truck runs fine with 108k miles on it.
Old Apr 4, 2014 | 10:05 PM
2006BLKMegacab's Avatar
which turbo boost sensor code?
if it is the Manifold absolute pressure sensor you can clean them, I tried to search for the how to clean info but I'm way too short on sleep to find what I'm looking for
Old Apr 5, 2014 | 09:31 AM
Rrloren1's Avatar
P2579 is code I'm reading.
Old Apr 5, 2014 | 03:04 PM
Being as P2579 is a "Turbocharger Speed Sensor Circuit Performance" issue I honestly have no clue as to what can and or should be done to rectify it, hopefully a smarter member than me will chime in and help you out, sorry!
Old Apr 6, 2014 | 05:25 PM
xcc_rider's Avatar
Go here: Posting Links to Copy Write protected is not allowed on DTR
Download the 2008 Factory Service Manual (you'll need it in the future and its FREE!).
Page 2367 is the diagnostics for the code.
Mine was a bad speed sensor and replaced under warranty. Its real easy to do yourself and not an expensive sensor either.
Old Jul 11, 2014 | 05:43 AM
Rrloren1's Avatar
The original code P2579 has gone away replaced by P2580.
The Repair Shop says replace it but the truck runs great, what does the speed sensor do and does it really need to be replaced?
By the way they want $582 for the sensor , I found it for $180 but not sure I need to replace it.
Old Jul 11, 2014 | 08:56 AM
xcc_rider's Avatar
If it is the speed sensor then it will run better if replaced.
Here's an excerpt from the forbidden service manual on the current code: The turbocharger speed sensor is a variable reluctance speed sensor. It consists of a coil of wire and an iron core. The target on the turbocharger shaft is a ground flat in the center of the shaft. As the flat on the turbocharger shaft spins past the speed sensor, a signal is generated. The ECM interprets this signal and converts it to a turbocharger speed reading. If this fault becomes active the ECM will light the MIL light immediately. During this time the ECM uses an estimated turbocharger speed. An engine power derate may be experienced. The ECM turns off the MIL when the diagnostic runs and passes in 4 consecutive drive cycles.
• When Monitored:
When the key is on and the ECM detects a valid turbocharger speed.
• Set Condition:
ECM detects turbocharger speed detected is less than a calibration limit for a calibratable amount of time.
Old Jul 11, 2014 | 10:17 AM
Rrloren1's Avatar
Thanks rider , guess I'll just replace it.
Old Jul 26, 2014 | 10:42 AM
Rrloren1's Avatar
As a followup I just had the sensor replaced and the code is gone but I've only put a few miles on it. Don't really see any improvement in performance.
FYI, the Dealer wanted $582 for the sensor , I bought it on the internet and for $188 had it delivered to my door. It was labeled an OEM cummins part. What a ripoff from Dealer !!
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Pinkston
Apr 4, 2006 08:54 PM
Booost Almighty
Jan 1, 2006 01:41 PM
bkay
Jan 24, 2003 11:11 PM
