turbo boost pressure sensor (MAP)
Re:turbo boost pressure sensor (MAP)
yeah <br>Pressure (mmHg) Voltage (V)<br>0 .44-.56<br>646.48 1.44-1.56<br>1292.88 2.44-2.56<br>1939.36 3.44-3.56<br>2585.76 4.44-4.56<br><br>IT has -A, B, and C labeled on it and the 5 volts DC is on A. B is pressure return and C is the pressure signal. 4.75-5.25 is ok to have as supply. Mesure the voltage from pin a to pin b.<br>hope this helps<br>Chase
I'm sure the plugs are different from '01 or so and up but I also thought that the calibrations on the map sensors were different.. so Slim is that info for '01 or the early ones??<br><br>Thanks,
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=ATEAV8GN link=board=4;threadid=9755;start=0#96148 date=1043436243]<br>I'm sure the plugs are different from '01 or so and up but I also thought that the calibrations on the map sensors were different.. [/quote]<br><br>Slim quoted you the 98.5 - 2000 voltages. The 01 and 02 start at 1.05 volts, and work up from there (don't know what the rest of the values are, sorry). Bus voltage still remains around 5 volts.<br><br>Rod
BigDiesels
Jul 29, 2009 04:32 PM
Moobesor
Feb 23, 2008 09:57 AM
Booost Almighty
Jan 1, 2006 01:41 PM
