Hard to get in gear
Old Jan 24, 2003 | 09:31 PM
1big44's Avatar
Hard to get in gear
Actually sometimes it is impossible to get it to slip into any gear.<br><br>I have NV5600 with a Southbend clutch with about 30k on it.<br><br>I'm almost postive I know the problem, but it comes and goes. Sometimes it works perfectly then sometimes you have to kill it to get it in gear. It will cause problems for a couple of days then be just fine for 2 weeks. This part has me confused.<br><br>Maybe someone can give me a happier solution.<br><br>Thanks,<br><br>Wes
Old Jan 24, 2003 | 11:19 PM
Bart Timothy's Avatar
Re:Hard to get in gear
Check your clutch hydralics - specafically the master cylinder. Fluid is probably leaking past the front seal and returning to the tank when the pedal is depressed.
Old Jan 25, 2003 | 04:44 AM
pappyman's Avatar
Sounds like something in your clutch assby is not releasing completely ???
4969joes
Mar 27, 2010 08:58 AM
AllPlay
Mar 29, 2008 02:13 PM
bhuffstutter
15
Dec 20, 2007 12:04 PM
salvagesavage
Feb 24, 2007 07:22 PM
getblown5.9
16
Sep 9, 2005 08:38 AM
