Hard to get in gear
Actually sometimes it is impossible to get it to slip into any gear.<br><br>I have NV5600 with a Southbend clutch with about 30k on it.<br><br>I'm almost postive I know the problem, but it comes and goes. Sometimes it works perfectly then sometimes you have to kill it to get it in gear. It will cause problems for a couple of days then be just fine for 2 weeks. This part has me confused.<br><br>Maybe someone can give me a happier solution.<br><br>Thanks,<br><br>Wes
Re:Hard to get in gear
Check your clutch hydralics - specafically the master cylinder. Fluid is probably leaking past the front seal and returning to the tank when the pedal is depressed.
Sounds like something in your clutch assby is not releasing completely ???
