P2242 code
Old Aug 15, 2011 | 06:04 PM
mlair921's Avatar
P2242 code
I've got a p2242 turbo boost mechanical code today. Has anyone had this code and how can I fix it? Thanks
Old Aug 15, 2011 | 07:32 PM
mlair921's Avatar
Sorry typo on code number it's us a p2262 turbo boost pressure nit detected - mechanical any ideas on fixing it?
Old Aug 15, 2011 | 09:53 PM
gcssr's Avatar
this may help;;;;;;;;;;;;;;;;;;;;Note this info is not for my 04.5
Well look at what I found out from Dodge about this code. I think I may be taking my truck to the big city of Wichita because the small town Service Department is lost. http://www.cumminsownerz.com/PDF/11-001-08.pdf
Old Aug 16, 2011 | 09:30 AM
cbrahs's Avatar
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of Chrysler Group LLC.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 09-002-09 DATED
MAY 2, 2009. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND
INCLUDE PARTS AND SPECIAL TOOLS/EQUIPMENT REQUIRED TABLES.
THE wiTECH DIAGNOSTIC APPLICATION IS THE PREFERRED METHOD FOR
FLASHING ECUs.
HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS
AVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OF
THE wiTECH DIAGNOSTIC APPLICATION WINDOW.
THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE 9.05 OR HIGHER TO
PERFORM THIS PROCEDURE.
StarMOBILE DESKTOP CLIENT, StarMOBILE STANDALONE MODE OR StarSCAN
MAY ALSO BE USED TO PERFORM THIS PROCEDURE.
SUBJECT:
MIL Illumination Due to DTC P2262 - Revised Diagnosis and Repair Procedures
OVERVIEW:
This bulletin discusses revised diagnostic and repair procedures for DTC P2262 -
Turbocharger Boost Pressure Not Detected - Mechanical. Recent PCM calibration
updates have improved the robustness to this DTC through updated diagnostic strategies.
As a result, many events which have no adverse affects on drivability, emissions, or
reliability will no longer set the P2262 fault.
MODELS:
2007 - 2009 (DH/D1) Ram Truck (2500/3500)
NOTE: This bulletin applies to vehicle equipped with a Cummins 6.7L engine (sales
code ETJ).
NUMBER: 09-002-09 REV. A
GROUP: Engine
DATE: June 13, 2009
**PARTS REQUIRED:
Qty. Part No. Description
(AR) *68048234AB Turbocharger, Kit
(AR) 68044565AA Cleaner, Diesel Turbocharger (water base)
1 (AR) 68050416AA Plug, Turbocharger Cleaning Port (stainless steel)
2 (AR) 05019845AA Plug, Exhaust Oxygen Sensor w/ Metal Gasket. (Note:
Plugs and Gaskets are required for repair, but can be
saved and reused).
NOTE: *When/if replacing Turbocharger, p/n 68048234AA or 68031095AA must NOT
be used on a D1/DH (Pick Up) models. Turbocharger p/n 68048234AA or
68031095AA are to be used on DA/DC/DM (Cab/Chassis) ONLY.
SPECIAL TOOLS/EQUIPMENT REQUIRED:
582000 wiTech System
10138-UPD Cummins Engine Update Kit - (includes kits 10142 &
10143)
10142 Turbocharger Cleaning Kit
10143 Turbocharger Drill/Tap Kit
10143-4 Drill Bit and Stop (Replace drill bit only when worn, as
required)
10143-5 Tap and Stop (Replace tap only when worn, as required)**
NOTE: Using the wiTECH Diagnostic Application for flashing an ECU is made
available through the wiTECH Diagnostic Application. For instructions select
the “HELP” tab on upper portion of the wiTECH window, then “HELP
CONTENTS.” This will open the Welcome to wiTECH Help screen were help
topics can now selected.
NOTE: While the wiTECH tool is the preferred method of testing and flashing,
StarMOBILE desktop client, StarMOBILE standalone mode OR StarSCAN may
also be used to perform this procedure.
NOTE: Please read through this entire Service Bulletin to gain a full understanding
before performing the procedure.
DISCUSSION:
Malfunction Indicator Lamp (MIL) illumination due to Diagnostic Trouble Code (DTC):
P2262 - Turbocharger Boost Pressure Not Detected - Mechanical.
As a result of recent PCM calibration updates, the proper repair for some P2262 faults is
to just update the calibration, while others will require cleaning or replacing the
09-002-09 REV. A -2-
turbocharger. Scan Tool software update 9.05 (and later) includes a P2262 diagnosis test
for this purpose. This diagnostic test uses Freeze Frame data stored in the PCM and a
dynamic turbocharger response test to determine the correct repair for each truck with
DTC P2262.
The new P2262 diagnosis test must be used prior to performing any of the following:
· Clearing codes.
· Updating the PCM.
· Beginning the turbocharger repair.
The test must be used with the key in the run position with the engine off, and with coolant
temperature between 50ºF and 180ºF. The time required to run this test will vary with the
calibration level of the truck, from a few seconds up to a couple minutes. This is normal
operation for the test.
NOTE: The P2262 diagnosis test MUST NOT be used after the repair is complete, as
this test CANNOT be used to confirm the repair. Test results will be
inaccurate.
If the customer is experiencing MIL illumination due to Diagnostic Trouble Code (DTC):
P2262 - Turbocharger Boost Pressure Not Detected - Mechanical follow the revised
diagnosis and repair procedures below.
DIAGNOSIS:
1. Connect the Scan Tool to the Diagnostic Link Connector (DLC).
2. Turn the ignition key to the ‘RUN’ position, DO NOT start the engine.
3. From the “Vehicle View” screen on the Scan Tool select:
a. “All DTC's” button.
4. Record all Diagnostic Trouble Codes (DTC's) that are present in the PCM.
NOTE: DO NOT erase DTC’s or reprogram the PCM at this point. If P2262 is not
present in the PCM due to clearing the faults or reprogramming the PCM, the
P2262 diagnosis test in Scan Tool will not run.
NOTE: It is IMPORTANT to record (capture) all DTC's present in the PCM prior to
proceeding further with this diagnosis. Procedures later may cause all DTC's
to be erased.
5. Is DTC P2262 present in the PCM?
a. If YES >>> Proceed to Step #6.
b. If NO >>> Then STOP. This bulletin does not apply.
6. Confirm the engine coolant temperature is between 50ºF and 180ºF.
7. Perform the P2262 diagnostic test with wiTECH®, From the “Vehicle View” screen
select:
a. Select “PCM”.
b. Select “Systems Tests”.
c. Select “P2262 Fault Diagnosis Test Start”.
d. Follow on-screen prompts to complete test.
NOTE: If you receive an error message from test, confirm that the Diagnostic Link
Connector and turbocharger actuator harness connections are secure. Also
confirm that engine coolant temperature is between 50ºF and 180ºF, then run
the test again.
-3- 09-002-09 REV. A
8. Based on the outcome of the P2262 diagnosis test, the Scan Tool will provide one of
the following as the proper direction for the appropriate repair. Based on these results,
refer to the detailed service information available in DealerCONNECT >
TechCONNECT under: Service Info and complete the repair as directed;
a. Update PCM Flash Calibration to the latest calibration. No repair required to
the turbocharger.
b. *Clean the Turbocharger.
c. Update PCM Flash Calibration to the latest calibration and Clean the
Turbocharger.
d. Replace the Turbocharger.
e. Update PCM Flash Calibration to the latest calibration and Replace the
Turbocharger.
NOTE: *If results of P2262 diagnosis test result in “Clean the Turbocharger” for a
SECOND time within 5,000 miles, Turbocharger should be replaced.
9. Does the vehicle have other DTC's as recorded in Step #4 above?
a. Yes >>> Follow appropriate diagnosis procedures or TSB related to diagnosis and
repair of each fault.
b. No >>> Repair complete.
NOTE: All other DTC's or symptoms MUST be addressed prior to returning the
vehicle to the customer.
NOTE: When/if replacing Turbocharger, p/n 68048234AA or 68031095AA must NOT
Old Aug 17, 2011 | 07:23 AM
Scotty's Avatar
Top's Younger Twin
This ^^^^^^ is why you were not posting much lately?
Come on Chris, get with someone that can show you how to copy and paste.
I bet that took you days to type, proof and post.
Its not just your 9 volt Komodo chair that needs some help.
HAHAHAH
BIG BAM!
Thread side tracked successfully.
Good info too.
Old Aug 17, 2011 | 08:30 AM
cbrahs's Avatar
just wait til i post the TSB for the kubota chair. its going to be 10 pages long as to why you don't do it with a 1970 **** carpeted lazy boy. still has disco lights and colored orange/green screaming the beegee's down the driveway and your neighbors are getting a little mad because this is the only song it plays.
BAM!!!
Old Aug 17, 2011 | 08:38 AM
cbrahs's Avatar
i have had reports of you crusing around at night jammin this one thru the 10" realistic sub on the kubota chair
Old Aug 17, 2011 | 09:44 PM
Scotty's Avatar
Top's Younger Twin
Yo Chris, you ok? Some of what you post is true but its all about you...or your envy of the KUBOTA MOBILE...it rocks.
Cool video's. Where did you get such nice outfits and how did you manage to sing such high notes? Uhhh don't answer that.
Go give the 9 Volt a Jolt lightweight.
Old Aug 18, 2011 | 07:53 AM
cbrahs's Avatar
can't be me. thats before my time!
mlair921
Aug 15, 2011 09:49 PM
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
