Long Crank on the 6.7
Old Oct 30, 2007 | 03:21 PM
donandcat's Avatar
Does anybody have the long crank issues on their 6.7 like we had on the 5.9 standard trans
Here so far so good
Old Oct 30, 2007 | 05:47 PM
KMKDiesel's Avatar
Mines not bad but seems like it should start upalittle faster takes 5 or more seconds
Old Oct 30, 2007 | 06:28 PM
sabersix's Avatar
Mine is almost immediate. Certainly not more than two seconds.
Old Oct 30, 2007 | 08:59 PM
KMKDiesel's Avatar
Forget to say mine does it 50% of the time the rest it starts right up
Old Oct 31, 2007 | 01:00 AM
Flattman's Avatar
Same here.
Old Jan 28, 2010 | 10:19 PM
Posm's Avatar
I find that if I wait a two or three seconds my truck starts right up. If not it will take much longer than my 5.9.
Old Mar 10, 2010 | 06:32 PM
dodge_kid9712's Avatar
i was just about to post about this problem.. my long crank is intermittent also. sometimes it will start right up within a second sometimes takes about 4 seconds it only takes long like 30-40 percent of the time though..does anyone think this is a problem?
Dont ask why but i ran out of gas before with but put a gallon in bumped the starter and it started right away. read that there is no prime button like the old 5.9s
Old Mar 10, 2010 | 07:30 PM
Blake Clark's Avatar
I have found that If I just jump in my truck and try to start right up sometimes I get a longer crank time. If I let the chime ring once I find it cuts down on the crank time.
But relatively, its still a rather long crank time compared to my '90. That sucker fires off on a half spin of the starter.
Old Mar 10, 2010 | 08:41 PM
whiteeye42's Avatar
I am having the same problem sometimes it starts right up and other times it takes a few seconds hope it is not going to be a big problem. I did notice the other day after a road trip of 400 miles and the batteries fully charge it started right up everytime so i am wondering if it might be the batteries going bad
Old Mar 10, 2010 | 08:43 PM
Ive already had to replace the batteries on mine. Passenger side was bad. It wasnt a long crank issue though. It was a no crank issue.
Old Mar 10, 2010 | 11:08 PM
Lil Dog's Avatar
If you treat it like a computer and let it boot before you start, it seems to keep it from having to catch up on the go. Even without the grid heaters, I let it sit for 5 seconds before cranking. The 97 is "dumb" and only needs a spin to get the fuel going, no computer there to fool with..
Old Mar 11, 2010 | 05:11 AM
Makes perfect sense
Old Mar 11, 2010 | 06:05 PM
jond1's Avatar
True, that's the secret.
Old Mar 12, 2010 | 02:02 PM
I was just thinking. That may also have something to do with the long tip start cycle on the new '10's that pop up every once in a while.
Old Mar 12, 2010 | 09:17 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
I always wait for the five "dings" before I bump the key or switch. Seems to be fine.
Rimcrew
Aug 19, 2012 01:04 PM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Feb 28, 2011 02:36 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
