Removing crank gear without pulling the crank out.
Old Jan 9, 2007 | 07:21 PM
aaronedwards82's Avatar
Do any of ya'll know how this can be done? And without hurting the other gears and surrounding pieces? Thanks in advance.
Old Jan 11, 2007 | 02:52 PM
dieseldemon's Avatar
Crank Gear
I pulled one of those once and it took about 40 ton to move, I don't think they make a puller that will move it
Old Jan 14, 2007 | 09:07 AM
tractortruck's Avatar
Not an easy task. My new crank I just installed did not come with the nose gear. I had to use the one off my old crank. Following the directions in the shop manual I tried with the heavy duty wheel puller, no luck. I ended up taking the whole thing to the machine shop, $25.00 and it was done. I know the shop manual specifies heat temps for pressing a new gear on the crank. Hope this helps.
tractortruck
12valvetom
Nov 27, 2009 11:37 PM
Yreka
Apr 17, 2009 05:04 PM
JaimeG
Mar 26, 2009 06:58 AM
DisplacedOkie
Jan 6, 2009 04:02 PM
u.s mma
Sep 6, 2008 09:25 PM
