Long Crank on the 6.7
Does anybody have the long crank issues on their 6.7 like we had on the 5.9 standard trans
Here so far so good |
Mines not bad but seems like it should start upalittle faster takes 5 or more seconds
Mine is almost immediate. Certainly not more than two seconds.
Forget to say mine does it 50% of the time the rest it starts right up
Originally Posted by sabersix
(Post 1766166)
I find that if I wait a two or three seconds my truck starts right up. If not it will take much longer than my 5.9.
i was just about to post about this problem.. my long crank is intermittent also. sometimes it will start right up within a second sometimes takes about 4 seconds it only takes long like 30-40 percent of the time though..does anyone think this is a problem?
Dont ask why but i ran out of gas before with but put a gallon in bumped the starter and it started right away. read that there is no prime button like the old 5.9s |
I have found that If I just jump in my truck and try to start right up sometimes I get a longer crank time. If I let the chime ring once I find it cuts down on the crank time.
But relatively, its still a rather long crank time compared to my '90. That sucker fires off on a half spin of the starter. |
I am having the same problem sometimes it starts right up and other times it takes a few seconds hope it is not going to be a big problem. I did notice the other day after a road trip of 400 miles and the batteries fully charge it started right up everytime so i am wondering if it might be the batteries going bad
Ive already had to replace the batteries on mine. Passenger side was bad. It wasnt a long crank issue though. It was a no crank issue.
If you treat it like a computer and let it boot before you start, it seems to keep it from having to catch up on the go. Even without the grid heaters, I let it sit for 5 seconds before cranking. The 97 is "dumb" and only needs a spin to get the fuel going, no computer there to fool with..
Originally Posted by Lil Dog
(Post 2722658)
(Post 2722658)
I was just thinking. That may also have something to do with the long tip start cycle on the new '10's that pop up every once in a while.
I always wait for the five "dings" before I bump the key or switch. Seems to be fine.
