Injector Nozzels
Old May 3, 2010 | 04:08 PM
neby's Avatar
Injector Nozzels
I am very close to having my truck running after it was in Hurricane Ike. I had the injectors tested and only one tested bad. It needs a new injector nozzel. Does anyone know where I can get one used injector nozzel for a 6.7L 2007 diesel? I was hoping to avoid buying a whole set. or a whole new injector.
Old May 4, 2010 | 05:25 PM
mega-engr's Avatar
"California Style"
I believe the injectors are programmed and matched into your trucks computer. You can't just swap them out. Truck won't run. In the least, I think you have have your computer "learn" the new injector, let alone all of them again at one time...
Old May 5, 2010 | 10:25 AM
Lil Dog's Avatar
There are aftermarket nozzles available from DDP if you wanted to upgrade for a cost less than OEM replacements.
I was corrected on the VIN lock to the injectors.. They are "trim" locked where the ECM has a trim value that is input into the program and the engine monitors performance to adjust. I don't know that anyone has just put in aftermarket nozzles without running a programmer or box.
Old May 5, 2010 | 11:05 AM
Scotty's Avatar
Top's Younger Twin
What does this mean? Trim locked? How does a person swap injectors and do this? Is there a way to get the ecm to 'learn' about the new injectors with some kind of procedure without having to go to the dealer? Maybe a key on key off push the throttle pedal, roll down the passenger window half way and put the wipers on high?
Old May 5, 2010 | 03:10 PM
mega-engr's Avatar
"California Style"
I believe the trim is a sort of coefficient that each injector has based on its performance/testing that the computer needs as they just are not all identical but the computer can adjust for the known differences.
Not sure if this value needs to be programmed into the ECM or it can be learned by the program as a part of the injector itself and electrical connection.
Old May 5, 2010 | 05:44 PM
Lil Dog's Avatar
Hey, I'm no expert, just tryin to learn here. Either way, the point was after you change nozzles I don't know that you can actually run it without a programmer of some sort.
Old May 5, 2010 | 08:13 PM
Scotty's Avatar
Top's Younger Twin
How can we find out J? Its a thing I would like to know and like lots of stuff, the dealer can make it mysterious and then someone comes along and points out an easier and more affordable way to resolve.
Lets Learn...its part of BOMBing.
Old May 6, 2010 | 07:17 AM
neby's Avatar
I know a guy that works at a dealership and is one of their senior techs. The whole reason for only swapping the nozzels is so I don't have to edit their number in the computer. Every injector for the 6.7l has a number on the side that must be in the computer or it won't fire. This value is changed with a Starscan computer or similar dealership type computer. If I change the injector, then I have to drag the truck to someone's shop, which is 50 plus miles in my case. And, I don't have a truck to pull it with since mine is undergoing surgery. So...I just need one nozzel to swap out with mine. Will a nozzel from a 5.9l fit? Any other input on the subject?
Old May 6, 2010 | 07:33 AM
Blake Clark's Avatar
Agreed
This in on my 6.7 to do list.
I wonder if Marco could answer such a question?
Old May 6, 2010 | 11:52 AM
Lil Dog's Avatar
Marco or Don M..
Old May 6, 2010 | 04:40 PM
Scotty's Avatar
Top's Younger Twin
So swapping the tips is the way around the 'learning'? Is that correct? Anyone got a tutorial on how to do that?
I'd be into altering the tips but I still want to add some cooling in the cylinders...would low dose washer fluid blend work?
Old May 6, 2010 | 05:29 PM
mega-engr's Avatar
"California Style"
Yes, I think this is Neby describes if this is possible. Otherwise, I think one is stuck with the Starscan and dealer to marry any new number to the program.
Old May 6, 2010 | 09:28 PM
Scotty's Avatar
Top's Younger Twin
Next up should be a tech article on how to swap the tips. Even include the R&R. I know that part of the task...just need to learn the tip swap.
Scotty
RyeThomas
Dec 6, 2006 08:00 PM
adidasman23
Nov 17, 2006 04:22 PM
ct2500
Nov 12, 2006 09:58 PM
dieselho
Feb 20, 2005 09:33 AM
