How to check for code?
Old Oct 6, 2007 | 09:27 AM
Gbuilders's Avatar
I had my engine light come on yesterday and was wondering how I could check to see which code it is? I have over 15K miles and it's been great so far. I have had all the latest flashes done and this is my 3rd check engine so far. Can anyone help? Thanks
Old Oct 6, 2007 | 09:34 AM
vzdude's Avatar
DTR's 'Go to Guy'
O.K. turn the key from off to on 3 times ending in the on position. Then the code will appear in the odo. screen. Also .......go to the user cp section on the upper left of your screen and fill out your sig. These instructions are for a 3rd gen since that is where you posted, and due to the miles on your truck , I have to assume!
Click here to get the description of your code
Old Oct 6, 2007 | 03:30 PM
skeeterboy's Avatar
Checking codes
Also keep in mind that the parking brake may need to be set.
That is the only way it will check the code for my 2007 6.7
Also mine throws a code for turbo [ no boost detected ] and [ no catalyst detection] every once in awhile. When the ecm or pcm runs its checks if it picks it up it will reset.
Hope this helps...
Old Oct 9, 2007 | 05:34 PM
Gbuilders's Avatar
Thanks for the help guys.
Old Nov 2, 2007 | 05:04 PM
Gbuilders's Avatar
Today the engine light came on again and I tried to get a code but it says System OK and the odo just shows the mileage any Ideas? The last time it came on the dealer said to run it at high speeds with the EB on and that will fix it and it did. So I'll try that again this weekend.
Old Nov 2, 2007 | 05:09 PM
KMKDiesel's Avatar
If it is showing the milage and no ----- you are notdoing it correct. Remember you have to turn your key all the way off , pushing the key release button. Cycle 3 times ending with on.
Old Nov 2, 2007 | 08:58 PM
sg138's Avatar
I just got the engine light and tryed to read the code and got nothing? will go by the dealer in the moring to see what is the problem
Old Nov 3, 2007 | 10:18 PM
CaptSanner295's Avatar
I just got the Malfunction Indicator Light on as well. Tried the 3 on and off and nada. Didnt do anything different then normal start up. We talking one click forward or two? System says ok. The light came on while driving. If the light is on does it always throw a code and does the parking brake need to be on?
Thanks.
Old Nov 3, 2007 | 10:21 PM
vzdude's Avatar
DTR's 'Go to Guy'
off to the on position 4 times. not cranking! some people have reported needing to have emergency brake on as well.
Old Nov 3, 2007 | 11:12 PM
I just put the parking brake on. Key one click forward 4 time quick and nothing. Then tried 2 clicks forward nothing. How fast do you do it. I understand its not hard but its just not working.
Old Nov 3, 2007 | 11:17 PM
KMKDiesel's Avatar
3 not 4 and all the way forward without starting and back like you are going to take the key out hold one hand on the key release button so you can get the complete key cycle 3rd time leave it on. If you have a code it will come up if done right if more then one code it will have ----- then next or ---- then done.
madhat
68
Oct 25, 2015 08:25 AM
Adam3291
May 2, 2008 10:08 PM
Gary C
Mar 15, 2004 02:53 PM
ck1
May 10, 2003 08:27 PM
