EGT's when cleaning DPF
When cruising along on fairly level ground I am seeing about 850 post turbo (probe is mounted in the elbow right after the turbo). Occasionally I will see 1050 plus for a few minutes. I "assume" the DPF is being regenerated during this time. But have no way of independently verifying that it is.
FWIW I was concerned about my mud flaps, but they are still in good shape at 8500 miles.
Wow - 850 post turbo? That's quite a bit higher than my 4.5 post turbo. I usually run about 500-600, measuring with a post-turbo pyrometer.
JWhitman
How did your pre turbo install go?
On the 2007 I wanted to install the EGT probe preturbo but didn't want to drill unless I could remove the turbo before drilling.
After looking it over decided I didn't want to remove the turbo.
fishnfreak86
Jun 11, 2014 08:44 AM
rip 112
16
Jan 15, 2010 02:46 AM
teamroper08
Jun 2, 2009 09:33 AM
