Code P 0205 on a 07.5 6.7L
Old Jan 11, 2008 | 06:19 PM
K2Cummins's Avatar
I found what it means. P0205 Injector #5 Control Circuit.
Anyone know what it means in english or what would cause it?
I found someone on another forum with the same code but he had an 05 5.9.
Old Jan 12, 2008 | 08:16 AM
K2Cummins's Avatar
Anybody else have this code on a 6.7?
Old Jan 12, 2008 | 05:44 PM
sweeney186's Avatar
Running rough as well?if so most likely a bad injector(internal short)
Old Jan 12, 2008 | 06:25 PM
vzdude's Avatar
DTR's 'Go to Guy'
Possibly a wiring issue inside the valve cover too. Not unheard of to have it happen fairly early if the wires were pinched.
Old Jan 12, 2008 | 06:37 PM
gmctd's Avatar
Go out, pop the hood, see if you see anything around the #5 injector wiring, between the main harness and the engine - if nothing peculiar, MrMoservice can check it with the DRBIII
Old Jan 12, 2008 | 07:50 PM
vzdude's Avatar
DTR's 'Go to Guy'
Who is MrMoservice? He'll have to use a Starscan though!
Old Jan 12, 2008 | 08:24 PM
sweeney186's Avatar
6.7l uses wiring embedded in the rubber valve cover gsk to prevent the prob. found on the 5.9l.I have seen this inj issue on several 6.7l arleady
Old Jan 12, 2008 | 10:19 PM
nubby3's Avatar
My truck 2007.5 6.7 had the same problem,took to dealer #5 cylinder misfire. had to change the wiring harness.I don't know what the code was.Truck only had 500 miles.
Old Jan 12, 2008 | 11:21 PM
K2Cummins's Avatar
Mine only has 800 miles. Going to the dealer Tues. morning for the G30 recall so they can look into what caused the code while its there.
Old Jan 13, 2008 | 12:21 AM
gmctd's Avatar
MrMoservice = yer friendly Mopar service manager at DCX
MrMoservice = MrGoodwrench equiv at GM
Also is MrMoparts, across the parts counter
Old Jan 13, 2008 | 12:25 AM
vzdude's Avatar
DTR's 'Go to Guy'
O....i C !
Old Jan 16, 2008 | 09:00 AM
K2Cummins's Avatar
Well I dropped it off at the dealership yesterday morning. Halfway to the dealership it started running kinda rough. It almost sounded like it was running on 5 cyls; definitely misfiring. Hopefully it is just a pinch in the injector wiring harness. Will keep you posted when I hear from them.
Old Jan 22, 2008 | 08:54 AM
K2Cummins's Avatar
Truck is ready. It was a problem with the wiring harness.
Old Jan 22, 2008 | 08:55 AM
vzdude's Avatar
DTR's 'Go to Guy'
Glad to know it wasn't anything major!
grunthmc
Jul 2, 2014 05:27 PM
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
