Click, then dead, no start, but lights
I have an '07 6.7 CTD with just over 108K miles. It's a stick. Late last night driving home from quick trip to close store I hear a click and then the engine dies. I got safely off the road. When I turn the key on all the dash lights come on except the grid light and there are no sounds like a starter solenoid. The engine doesn't try to start.
I had time waiting for the tow truck so I pulled every single fuse I could (all except the caged ones which I've never seen before). None were bad. I know most of the fuses wouldn't help but I had nothing else to do.
Early yesterday the engine light came on when I was running errands around town. This happens about every few months. A dealer told me long ago that it just means your fuel cap is lose. So I filled up the tank and made sure the cap was on tight. The light still came on.
I just read in another thread about an "INTERNAL Check of your ECM and PCM. To do that turn the key OFF then ON two times, but don't try to start the truck. Wait a second or so and watch your dash and be prepared to write down some code numbers." I tried this but didn't see any codes.
Any suggestions? The dealer won't be open for a couple of days and I could really use the pickup.
BTW the reason I don't have much of a post count here is that I've been very fortunate with my pickup and not had too many problems.
Checked the overhead display for messages. It only says Low Fuel, but the fuel light on the dash goes out and I just filled the tank about 10 miles ago. I also noticed that the elapsed time was reset and the Avg MPG has no value.
To perform that test, you actually need to cycle the key on THREE times, ending in the "on" position. If there are any fault codes in the ECM it will display them in the odometer.
I am trying to think of a condition that would cause the engine to die, and also prevent the starter from cranking. Right now I am thinking of a main power feed or ground fault. Hopefully there's a fault in memory that might steer you in a direction.
From: In Oroville, Ca., same house for past 46 yrs!
If you heard a "pop" sound it might be a massive overload (for some reason?) that caused a fuseable link to go. Look for a heavy gauge wire that's got two ends just loose, might be a start in the right direction.
Sleigher
Mar 23, 2007 12:23 PM
cheapskate
19
Dec 27, 2006 08:05 PM
PaulDaisy
Dec 2, 2006 12:36 PM
