cant remove front drive line
Old Jun 19, 2009 | 03:45 PM
rolling18's Avatar
how do you remove the front drive shaft at the t-case end?? i removed all 4 bolts and it still wont budge!!
any tips for the 4 torx bolts at font end?
thansk!!
yes i tried searching but did not find anything about it not coming out
also would play at the double cardon joint at the t-case end cause high speed vibrations? (70 on up)
Old Jun 19, 2009 | 04:21 PM
bngcustoms's Avatar
You should just be able to take a punch and a hammer and tap the drive shaft flange towards the front of truck. A little rust might have it stuck. On the torx bolt you have to have a long shanked torx socket, once you have the TC end off you push the drive shaft up to the body as high as you can then remove bolts. Remember to mark the drive flanges on the drive line and on the TC and the front diff before you remove it.
Old Jun 19, 2009 | 06:14 PM
N.Johnson's Avatar
bngcustoms is right on, as that was how I got mine off. Used a block of wood to wedge the shaft up so I could get a straight shot at the torx heads at the diff.
I found out the hard way that the torx head bolts are assembled at the factory with red loctite. Stripped the head on one before I clued in. Get a small butane torch and heat the bolts , being careful not to let the heat get to the yoke seal, did one at a time to limit the heat.
The joints I used at the double were two precision 351, the joint at the front is precision 351A.
Old Jun 19, 2009 | 08:50 PM
rolling18's Avatar
ok thanks for the info!! ill give those a ty when the rain stops!
Old Jun 19, 2009 | 09:09 PM
rolling18's Avatar
for those of you who replaced your torx bolts what type/ where did you get them?
Old Jun 20, 2009 | 12:18 PM
TheMighty'67's Avatar
i replaced my torxs with the same grade bolt i think it nwas 10.8(i know its black) it was the same length and it had a hex head. I used lock tight and a lock washer to keep the head out of the recess, i got them a a local hardware(small town store)
Old Jun 23, 2009 | 12:44 PM
dj_souvlaki's Avatar
i got mine from the dealer. like 5 bucks for 4.
Old Jun 23, 2009 | 03:50 PM
rolling18's Avatar
ok thanks!! i got 2 our but partially stripped the other 2,,
Old Jun 23, 2009 | 05:56 PM
rolling18's Avatar
ok thanks guys i got the back part off, ill have o have a shop do the front cause of the partially stripped crappy loose fitting t40 bolts.. uhh!
CapnRam
Nov 6, 2012 11:07 AM
RoadDiesel
Aug 7, 2012 06:06 PM
Shawn.L.Turbo
May 22, 2009 09:25 AM
bansh-eman
23
Feb 24, 2008 07:36 AM
zukgod1
16
Jan 13, 2006 11:12 AM
