Front Drive Shaft Grease Point. Iv read allt he posts I cant find it
Old Jan 20, 2008 | 06:00 PM
bansh-eman's Avatar
i have read all the post and seen the picts. I still can not find that pinhole. there is no dirt on my drive shaft just a little rust.. i cleaned it all off i removed the skidplate to change my tranfer case oil and i still cant not find that hole...
is it on the transfer case side going t the front driveshatf? i can see one big nut in there and thats it. i have spun it and felt around but im either looking in the wrong spot or im bilnd cause i cant not find that thing
Old Jan 20, 2008 | 06:08 PM
Rpainter's Avatar
I read somewhere at some trucks dont have the grease fitting. check for a sticker on the radiator support to see if it has a fitting?? could be wrong though
Old Jan 20, 2008 | 06:30 PM
bansh-eman's Avatar
it shows in my owners manuel that it has it. but i cant find it
Old Jan 20, 2008 | 07:49 PM
rallydriver's Avatar
https://www.dieseltruckresource.com/...05#post1894105
-Chris
Old Jan 20, 2008 | 08:04 PM
mopardamo's Avatar
Dang Hole
When I looked I was not aware of the pin hole deal. I asked the Service Manager at the dealer and he had his diesel guy come over and answer. He said that my truck did not have the fitting. I'll bet when it warms up I find it now that I know it's a fruit pin hole fitting.
Damon
ps What is the proper way(button) on this forum to return to the page that you arrived from?
Old Jan 20, 2008 | 08:24 PM
mizzu's Avatar
Drive shaft grease fitting
My 06 has the sticker on the radiator. First time I had it back to the dealer I asked them and they said that the u-joints were sealed (no fitting). Not to doubt their expertise but I had a good look myself after seeing pictures posted here. They were right, no fittings. I have 47k on it now with some pretty good tows and everything is tight with no noise. I guess the jerks forgot to install the zerks.....
Old Jan 20, 2008 | 10:48 PM
Danavilla's Avatar
I also read that some trucks don't have the fitting, mine did. The u-joints themselves ARE sealed. The fitting is on the carden joint between the u-joints. Assuming it's there, of course.
Dan
Old Jan 20, 2008 | 11:18 PM
Fisherguy's Avatar
I've found mine but don't think I've ever been able to shoot any grease into the stupid thing!
Old Jan 20, 2008 | 11:24 PM
AlK's Avatar
AlK
bansh-eman,
This is not your typical (male) grease fitting, it is a female fitting. The fitting is on the transfer case end of the front drive shaft. You need to be able to turn the drive shaft - jack up one front wheel. Get a good light under there and slowly turn the drive shaft while looking look at the u-joint. You have to look towards the transfer case.
Here is a picture.
http://
Old Jan 20, 2008 | 11:30 PM
nelrod's Avatar
If it's that hard to find, take the 4 bolts off front driveshaft and then will be 10 times easier. Then mark it with yellow paint pencil after greasing and cleaning up and before replacing driveshaft. I did not realize some do not have it. I would just take the 30 minutes and look with shaft off and make sure. But that's just me.
Old Jan 20, 2008 | 11:39 PM
AlK's Avatar
AlK
Fisherguy,
I use a hypodermic needle to inject grease into the fitting.
Old Jan 21, 2008 | 12:19 AM
bansh-eman's Avatar
i was looking to far back. i was looking at the spot that has large nut is at. ill have to check it out again tomorrow and see if i have that
Old Jan 21, 2008 | 07:07 AM
Fisherguy's Avatar
Originally Posted by AlK
Fisherguy,
The needle type isn't the right one cuz it won't 'force' any grease into the joint. I've bought 2 of the proper ones so far, but still can't get any to go in...
Old Jan 21, 2008 | 08:12 AM
t-boe's Avatar
I use the needle to grease mine. Works great everytime.... once you turn the driveshaft into the right position of course.
Old Jan 21, 2008 | 08:20 AM
madhat's Avatar
Administrator/Jarhead
If you post, you gotta click the back button 3-4 times...
