ram 2500 died
well never thought i would say this but my 04 ram 2500 died on me getting onto the highway the other day. had to have it towed. that was a sad sight, broke my heart. the truck is throwing out code 0628 which seems to be the lift pump. the truck cranks but will not start but cranks good. had all kinds of power then it just fell flat on its face, no warning or anything at all. anybody have any suggestions? also just wanted to give everyone a heads up.
How many miles? I replaced mine at about 86k miles (I think). I was a PITA. I had to get another piece of fuel line with quick connectors, so if it fails on the road, I'll be able to replace the "new" LP with the original (which worked fine when removed).
update dealer confirmed it is the lift pump and is under warranty. the bad part is
that the part is on backorder. i cant get a break. hope to have my truck back this weekend as i am moving. oh ya they are replacing the engine mounted pump with a tank mounted pump. will i gain any power?
Sorry, warranty or not, they ain't doing that to my truck. At least with the engine mounted pump, you could change it along side the road.
update dealer called me yesterday and said truck was ready!!!! i miss my truck and cant wait to pick it up. hopefully it runs good and the injection pump was not damage when the lift pump went.
That's a "VP" prob.....not a "CP" prob. You now have a very reliable truck in my experiences.
while you are at it put a piece of split spagetti cover over the wire at the a/c compressor. when my pump went at 83k,was replaced under warrenty, two/three day later engine stall and code for CPK thrown, moved wire and all cleared up, so i installed spaghetti shield, and all is ok now 96k
