Won't turn over 05' 2500 5.9
Hey guys,
I've been reading through and searching the forum but no luck with a solution...
My 05 2500 5.9 will not crank. It has flooded in Harvey but only about 6" above the transmission pan. Changed all fluids, and all the other things you amazing people suggested.
Now I'm ready to start her up! Well, everything looks good and all sounds right until I actually turn her over... Nothing. All lights and everything is as normal, but it is literally silent when I try to crank her up...
checked terminals, 2 new batteries, followed wiring... all looks good.
throwing 2 codes: P2509 & P0483
I replaced the fan clutch not too long ago and it spins as it should, so after all I've put into this already, I just hate to replace it again just to throw parts at her
I did just replace the radiator due to a crack.
Anyone have any ideas?
05 2500 5.9 laramie - stock
Engine was completly rebuilt in 2012, new injectors, new turbo, everything (just some history).
thanks!
thanks!
Thank you. Connections on the fan clutch? I checked and they look good. I'm going to check all the wiring on the starter today. It doesn't appear that the starter got any water. I'm not sure if it should be making some kind of noise or not. As well as run all the battery lines again...
