Wires to fan clutch cut in to
Old Aug 21, 2011 | 09:08 PM
dogcamo's Avatar
Found that the wires going to my clutch fan are cut in to. That would explain the poor AC at low speeds and increased engin and trans temps. Does the clutch fan need to be replaced or can new wiring be purchased? Is this a design flaw from Dodge?
Old Aug 21, 2011 | 09:36 PM
06RAM2500's Avatar
New clutch. Can fix the wires, but you may end up with more issues.
Old Aug 21, 2011 | 10:29 PM
Spooler's Avatar
Check the fan bearing on the engine and make sure the radiator is in it's mounts.
Old Aug 22, 2011 | 04:39 PM
dogcamo's Avatar
Is the brand Hayden a good fan clutch?
Old Aug 22, 2011 | 05:49 PM
06RAM2500's Avatar
I can't say for sure. What's the price, and where can you purchase? Also, what kind of warranty?
Old Aug 23, 2011 | 10:44 PM
papaduck's Avatar
I got my replacement at NAPA at a good price. Made in USA.
Old Aug 24, 2011 | 02:05 AM
TxDiesel007's Avatar
did the above as well..
make sure while you are at it, you can also wire loom the wires that the FC has on it, i wireloomed mine and got them out of the way, experience from others having the same problems taught me that one..
NAPAs FC is pretty good, and IIRC i got it for 260 or so out the door...
Old Sep 1, 2011 | 09:07 PM
ironbrew's Avatar
A friend of mine has suggested checking the fan for movement. I am considering electrics...
Old Sep 1, 2011 | 09:39 PM
maxwellp's Avatar
Talking
I have seen this come up many times, it may feel good but may not be. There is a thread that the guy was on clutch number three and that time replaced the bearing.
block61
May 1, 2016 11:26 PM
dogcamo
Aug 11, 2013 06:54 PM
idlewildranch
Mar 24, 2010 11:48 AM
feveree40
Oct 3, 2007 03:59 PM
chevota01
Sep 21, 2007 08:00 AM
