cut wires to fan clutch 04 ram 3500 cummins
Old Jul 7, 2013 | 08:38 PM
block61's Avatar
just bought this truck and love it........after about 1500 miles the engine running a little warmer than before....noticed the fan clutch wires had been "cut".by the fan.........I replaced the fan clutch....twice..........the wires are sucked in and cut ...every time........after driving only 3-4 miles..............need this truck on the road working....not apart and sitting......any help please?
Old Jul 7, 2013 | 09:55 PM
hot_runner58's Avatar
Can you get a wire tie, or zip tie around them and even just zip tie them to themselves to shorten them up, or even attach them to a wire harness or something? I'm not sure what is around the wires, so just throwing it out there. Or, go electric.
Old Jul 7, 2013 | 10:08 PM
kthiemann's Avatar
Make sure you are bolting the wiring to the fan shroud. Attached is the page from the FSM that shows how its mounted, it's for a 6.7 but if I remember right it's the same.
File Type: pdf
Old Jul 7, 2013 | 11:54 PM
BigIron70's Avatar
Cummins Guru
I went through same problem, it turned out to be excessive run out in the fan hub bearing. I changed it and haven't had any problems since. Do yourself a favor and replace it before you do any thing else. Three fan clutches and two radiators later I replaced it. Wobble in fan would start the wires at high rpm to whip then the wires would hit the fan blades, you know what happens next I'm sure.
Old May 1, 2016 | 08:43 PM
Clayton 798's Avatar
how much play was in the bearing? I'm not seeing any.
Old May 1, 2016 | 11:26 PM
BigIron70's Avatar
Cummins Guru
It was more of a wobble then actual play in the bearing. Truck came from another dealership after they couldn't fix problem. After they replaced several fan clutches and radiators. I replaced the hub assembly fixed the problem, comes complete with hub, bearing and bearing housing. This is the part I'm talking about.
PENSACOLA DIESEL 1205
dogcamo
Aug 11, 2013 06:54 PM
block61
0
Jul 7, 2013 08:35 PM
dogcamo
Sep 1, 2011 09:39 PM
feveree40
Oct 3, 2007 03:59 PM
chevota01
Sep 21, 2007 08:00 AM
