Clutch fan wires cut again
Old Aug 11, 2013 | 04:14 PM
dogcamo's Avatar
I'm at a loss. This is the second time the wires for the fan clutch have been by the fan. Can anybody explain why this is happening?
Old Aug 11, 2013 | 04:43 PM
BigIron70's Avatar
Cummins Guru
Notice any wobble in the fan when engine is running? then the flange and bearing should be replaced. Pull the fan and then mount with bracket 4 bolts. Put it on bench and spin it any run out noticed then best to replace it. Took another shop 3 fan clutches and 2 radiators before they brought it to me to correct the problem. Any run out at the #1 location will cause fan clutch wires to hit fan at higher rpm's.
Picture is from 2000 model year diesel different fan clutch used
Old Aug 11, 2013 | 06:54 PM
dogcamo's Avatar
Thanks for the info
block61
May 1, 2016 11:26 PM
dogcamo
Sep 1, 2011 09:39 PM
idlewildranch
Mar 24, 2010 11:48 AM
feveree40
Oct 3, 2007 03:59 PM
chevota01
Sep 21, 2007 08:00 AM
