Will this work and will it void warranty?
I have about 7000 miles on my truck and have been very strict in what mods I do in regards to the factory warranty. I have heard of this:
http://www.rokktech.com/_mgxroot/page_10437.html
And I have read the posts about this Rokkteck crankshaft sensor but have not seen a post that addresses this.
Will this void my warranty since I'm sure the computer will record a +2 degree change in the timing and will be detected if pulled up? OR---Does the Dodge specs specify + or - 2 degrees in which case it would be OK (within spec).
If its safe as far as Dodge warranty concerns, it will be a mod that I would do. Big " if " though
Thanks MikeyB,
I sent them my number to contact me. If the Sensor will do the same thing, I feel a little more comfortable putting it on rather than pulling the ring off and cutting it out, etc...and fighting with the bolts, etc.
Sounds like I can just keep my stock sensor, and put it back on if I ever go to a box that adjusts timing/duration etc....in the future. Am I right? Then it wouldn't over advance the timing and cause problems.
Originally Posted by TexasCTD
Thanks MikeyB,
MikeyB
Originally Posted by MikeyB
Yes, you could put the original sensor back on if going to a box that does timing or you can adjust the Rokktech back to the stock position.
MikeyB
MikeyB
Thanks again MikeyB,
I will order one as soon as they call me. Be nice if they had a phone number on their website for me to call. If they did, I didn't see it.
rkelley
Oct 12, 2006 06:59 AM
Shaders 24v
Aug 27, 2003 09:55 PM
clydesdale6
Feb 28, 2003 09:50 AM
latitud_rt
40
Jan 28, 2003 10:05 PM
